To glue, or not to glue?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Club 40 >> To glue, or not to glue?
Page: [1]
Login
To glue, or not to glue? - 1/23/2008 6:32:55 PM
DonStegall
Status: offline
I have always glued the stab and rudder on the Sky Raider Mach II's that I have put together. I usually mark around the fin and cut away the covering. And I remove the covering from the stab in the stab saddle area. Then I glue the whole stab and fin assembly together with the bolts inserted.
On most of my damaged planes, it has been a non-issue. But I did have one LA Racer 40 that would have been easier to fix if the stab had just been screwed in.
Is anyone not gluing the tail components in?
_____________________________
Don Stegall
RCPRO - http://www.rcpro.org - http://www.rcpylon.com
       Post #: 1
RE: To glue, or not to glue? - 1/23/2008 7:18:13 PM
vicman
Status: offline
I don't.
However I do put a liberal amount of loctite on the screws. We were out flying the other day just goofing around and I was getting some sick snaps out of mine. Enough that I got a little worried about what I may be doing to my "racing plane". It hasn't been an issue for me yet, heaven knows I have flown the snot out of mine.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to DonStegall)
       Post #: 2
RE: To glue, or not to glue? - 1/23/2008 8:12:31 PM
dwbebens
Status: offline
I haven't glued mine. The screws have stayed tight without Loctite. Also, I can remove the tail (and wing) so it will fit in our smaller car when I travel to races.
Doug Bebensee
(in reply to vicman)
       Post #: 3
RE: To glue, or not to glue? - 1/24/2008 11:30:40 AM
wb4snu
Status: offline
quote:
ORIGINAL: vicman
I don't.
Vic
The next time we fly together I'll bring some Kleenex for you. Some to wipe the plane butt and some to wipe your forehead from sweat.
Richard
IF IT''S NOT BROKEN THEN KEEP FIXING IT TILL IT IS
       Post #: 4
RE: To glue, or not to glue? - 1/24/2008 1:03:10 PM
Ed Smith
Status: offline
I always screw the tail in. easier to build, easier to fix and easier to make trim adjustments.
Ed S
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 5
RE: To glue, or not to glue? - 1/27/2008 9:41:57 PM
Ken Erickson
Status: offline
I have toyed with the idea of gluing, but never have. Used loctite on one. Wanted to remove it, but could not!!!
We had cases where the screws not only came loose, but fell out.
Now I just check the screws before each days flying and then put tape over the holes. Actually did not have one loosen all last year.
Ken Erickson
Columbus, IN
       Post #: 6
RE: To glue, or not to glue? - 2/2/2008 5:17:31 AM
jstaff
Status: offline
I have never glued the tail feathers, just used the screws provided. Now that I've gone through several Sky Raiders I have extra vertical and Horz. stabs and can make a quick change when damage occurs during a heat. I've had my tail feathers chewed on several times.
Jerry Stafford
(in reply to Ken Erickson)
       Post #: 7
RE: To glue, or not to glue? - 2/3/2008 2:02:04 AM
gunfighter
Status: online
Hey Jerry - That would not happen if you had a faster plane!!
See ya' soon my friend!
(in reply to jstaff)
       Post #: 8
RE: To glue, or not to glue? - 2/6/2008 3:46:23 AM
jstaff
Status: offline
I was wondering what was wrong! Now you tell me!
(in reply to gunfighter)
       Post #: 9
RE: To glue, or not to glue? - 2/7/2008 1:57:52 AM
stanlattrell
Status: offline
I have always glued the stab & fin in place -- old habits from many years of modeling. I've found the fin & stab alignment to be off enough so flight would be affected, and I need all the help I can get when I'm on the race course. I've also had a student with a screwed-on tail on his trainer that came off in flight and totaled his plane -- he checked and tightened the screws before the day's training session. Third flight of the day, and oops -- instant kit. Any SRM2 I've wrecked was bad enough that saving the tail would not have been a benefit - I would have lots of tails and no fuselages to put them on.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.813RCU1
