David Bathe
I'm surprized that nobody has mentioned engine RPM's because they're the reason your engine/aircraft combo is performing better with the Graupner... not the prop! The Teutonic blades are causing your engine to operate in it's high torque band... low-mid 8s rpms. Thus you're getting the "tractor" pulling power you mentioned. Because the APC is more efficient, it allows the engine to rev far higher even though it's the same size. As you've found out, high revs aren't necessarily the answer to great performance, high torque is. So what does all this mean? Quite simply that you can go a size bigger with the APC... possibly two, you'll have to experiment. Add an inch to the APC diamiter or even two and trim it back some... what ever, just end up with the R's about the same No's as with the Graupner. You'll experience a mighty increase in pulling power.
< Message edited by David Bathe -- 5/3/2008 3:01:56 PM >
_____________________________
Best Regards: David Bathe, Aircraft and Instrument Panel Illustrations.
