av8tor1977 -> don't forget echo! (6/5/2003 11:11 AM)
Hi, Thanks for the Walbro links. I had them a while back, but lost them. Well, there's two possibilities here. One, perhaps that "A" suffix means something. I didn't see an "A" suffix in those listings, and there is one model WA-138 that is says is unavailable and has no listing for the venturi size. The other, and more likely possibility is this: My "venturi", or carb throat, actually does measure around 11.5 mm, but that annular ring you see in the picture where the metering holes are is .279", or about 7 mm. It's not going to flow any more than the smallest area, so that's what I measured. I cleaned up a small casting ridge in that ring, and gained a few thousandths, but I was afraid to go any more. It now measures .282". The screw mounting the butterfly valve to the shaft was too long and obstructing flow, so I carefully ground it down too. I think that's as good as this little puppy of a carb is going to get! Now I'm working on gutting the muffler, and it is the only part of this project that has not been fun. What a pain! If I lived in the states and had access to my welders it would be easier, but then I would never fool with the stocker; I would build one out of aluminum!! Thanks again, AV8TOR
