RE: don't forget echo!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: don't forget echo!
Page: <<   < prev  1 2 3 4 5 6 7 8 [9]
Login
RE: don't forget echo! - 1/11/2008 9:42 PM
rangerfredbob
Score: 115
Last Login: 6/15/2013
Status: offline
if you're really going for weight loss, after you cut the end off of the crankshaft, drill a hole in it not deep enough to go through the other side, and leave about an 1/8" wall thickness... can't hurt anything
Hide Signatures
(in reply to Ralphbf)
       Post #: 201
RE: don't forget echo! - 1/12/2008 2:41 AM
mikenlapaz
Score: 100
Last Login: 2/26/2013
Status: offline
AV8TOR Neat idea. How much of the crank do you figure you off additional if it has already been trimmed to the outside of the seal? I'll keep that in mind when I get back to the Zenoah from parts project. Trading some aluminum for steel is a lightening idea!
_____________________________
trying to tax into prosperity is like a man standing in a bucket and trying to lift himself up by the handle W. Churchill
Hide Signatures
       Post #: 202
RE: don't forget echo! - 1/12/2008 4:51 AM
av8tor1977
Score: 665
Last Login: 6/17/2013
Status: offline
Just measure the width of the bearing, and cut the crank so that it has that much, or a touch less sticking out to penetrate the bearing.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to mikenlapaz)
       Post #: 203
RE: don't forget echo! - 1/12/2008 8:25 PM
denningpat
Score: 100
Last Login: 12/10/2010
Status: offline
quote:
Denningpat,heres what the echo "E" looks like.its on the base of the cylinder under the exhaust.It should also be on the back of the case somwhere around the pull start housing.most echos have 2 rings but not all.The one in the pic is a 16 or 18cc but only has one ring but it still has the E even though its old.If yours doesnt have the E i think it might be a shindaiwa or a mc'cullah.It really doesnt matter if your not going to do 3D anywway.It will more than likly fly any high wing airplane with at least 1000 sq inches of wing area in the 72-80 inch size very scale like.Youll get excellent fuel savings from glow and youll be able to use about an 6-8 oz tank.Im planning on putting my echo 17cc or my 23.6cc on my spook.(96)ws.1344 sq in wa.only weighs about 7.5 lbs empty.
Thanks for the info you guys have been real helpful. Has anyone converted one of these? I'll make sure and post outside of the Echo thread next time. Time to start converting.
< Message edited by denningpat -- 1/12/2008 8:27 PM >
Hide Signatures
(in reply to buck1856)
       Post #: 204
RE: don't forget echo! - 1/12/2008 11:58 PM
w5kfg
Score: 100
Last Login: 2/28/2012
Status: offline
quote:
ORIGINAL: av8tor1977
AV8TOR
Where can I get the cdi ignition module for the 23 cc echo conversion
Bill B
Hide Signatures
(in reply to av8tor1977)
       Post #: 205
RE: don't forget echo! - 1/13/2008 7:37 AM
buck1856
Score: 105
Last Login: 2/26/2012
Status: offline
rcignitions
chignition
theseare the only 2 ive dealt with but there are others if ya check the classifieds here on rcu.A few hobby stores online sell them.but i would personnally only deal with the 2 ive mentioned in my opion.
Hide Signatures
(in reply to w5kfg)
       Post #: 206
RE: don't forget echo! - 1/13/2008 8:04 AM
mikenlapaz
Score: 100
Status: offline
I second buck's statement.
Hide Signatures
       Post #: 207
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RE: don't forget echo!
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
