RE: Removing cam bearings from OS engine?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Removing cam bearings from OS engine?
Page: <<   < prev  1 [2]
Login
RE: Removing cam bearings from OS engine? - 2/5/2008 4:41 PM
Edwin
Score: 156
Last Login: 6/18/2013
Status: offline
Kmot, You forgot to clean that green stuff off your engine.<g> What paint is that? Powdercoat?
Edwin
Hide Signatures
(in reply to Kmot)
       Post #: 26
RE: Removing cam bearings from OS engine? - 2/5/2008 8:13 PM
Kmot
Score: 168
Last Login: 6/19/2013
Status: offline
Edwin, it is Dupli-Color engine enamel.
_____________________________
~Tom~
Hide Signatures
(in reply to Edwin)
       Post #: 27
RE: Removing cam bearings from OS engine? - 4/11/2011 11:48 PM
Campgems
Score: 143
Status: offline
Jens, That is a nice looking puller.  I tried making one last year after seeing your post on another thread, and it worked on the cap, but there wasn't enough room behind the bearing in the crankcase to get the jaws behind it.  I kept shaving them  until I could, then at  the first snug the end popped right off the shank.  It required a max thickness of 0.010" to get in behind the bearing.  It was at that point I moved to using the wax and a tamp rod.
This may have been just one engine, and it did work on the cap, but the fit was just too close in the crankcase for it to work.
I'm in the process of using your design though for a puller for main bearings.
Don
Hide Signatures
(in reply to Motorboy)
       Post #: 28
RE: Removing cam bearings from OS engine? - 4/12/2011 5:45 AM
Motorboy
Score: 115
Last Login: 10/23/2011
Status: offline
quote:
ORIGINAL: Campgems
Jens, That is a nice looking puller.  I tried making one last year after seeing your post on another thread, and it worked on the cap, but there wasn't enough room behind the bearing in the crankcase to get the jaws behind it.  I kept shaving them  until I could, then at  the first snug the end popped right off the shank.  It required a max thickness of 0.010'' to get in behind the bearing.
Don
You an use tapered end of the screw instead the rod in the hole at the puller. Let us say: The hole in the puller is treaded inside with tapered hole from mid of length to end of the puller + screw with tapered pin . When the screw is turned into, then the puller is expanded firmly in the inner ring bearing, then pull out the old bearing.
Jens Eirik
Carpe diem quam minimum credula postero
Hide Signatures
(in reply to Campgems)
       Post #: 29
RE: Removing cam bearings from OS engine? - 7/20/2012 4:02 PM
dbacque
Score: 137
Status: offline
Needing to disassemble a 1.20 Surpass sent me searching for information on how to get the cam bearings out. This is the thread that solved the problem for me.
I started out with a tool like the one that Hellcat 1 showed with just a single foot but I couldn't get it to work. I finally decided that I had to make the split tool for an even pull. But I don't have machine tools so I couldn't make a tool as fancy as Motorboy's, no way to drill for a center pin. What I finally came up with was a low tech method of making Motorboy's tool.
I made mine using a socket head capscrew, a grinder, a Dremel with a fiberglass cutoff wheel and a pair of Visegrips. Without the center pin the legs wanted to close up when I would try to pull the bearing. So I made a shim from a washer just barely too thick to fit between the legs. I cut the washer in two and then thinned one end of it forming a wedge.
Clip the tool into the bearing, reach in with a thin pair of needle nose pliers and seat the wedge between the legs, assemble the washer and bolts, then pop the whole assembly in the oven. It worked great!
I didn't bother slotting the other tip for a screwdriver, I just used a couple of nuts locked against each other. I also used the socket like Hellcat 1 to pull the bearing out of the cap.
Thanks for the help guys, couldn't have done it without you and I wanted to add a few notes on how I did it without specialized tools.
Dave
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 30
RE: Removing cam bearings from OS engine? - 7/20/2012 11:44 PM
Kmot
Score: 168
Status: offline
Nice adaptation Dave!
~Tom~
Hide Signatures
(in reply to dbacque)
       Post #: 31
RE: Removing cam bearings from OS engine? - 11/16/2012 10:28 PM
stewart69
Score: 100
Last Login: 6/14/2013
Status: offline
Hi, I made this little tool to get the stubborn cam bearings out, slips into the 5mm ID,tighten draw bar,apply some heat and pull. Fits OS singles and copies ie. ASP MAGNUM etc. PM me if you want one.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Kmot)
       Post #: 32
RE: Removing cam bearings from OS engine? - 11/18/2012 4:44 AM
Kmot
Score: 168
Status: offline
That's a real nice looking tool you made Stewart!
There's another guy also selling a tool for removing bearings in blind holes. It's pretty pricey, but it is a nice looking tool:
http://www.rcuniverse.com/forum/m_11252559/anchors_11300440/mpage_1/key_/anchor/tm.htm#11300440
~Tom~
Hide Signatures
(in reply to stewart69)
       Post #: 33
RE: Removing cam bearings from OS engine? - 11/18/2012 7:12 AM
stewart69
Score: 100
Status: offline
Yes that other tool is a nice bit of kit but does not come in the correct 5mm ID bearing size.Also I am concerned the pin may punch a hole in the crankcase behind the bearing,it is only 1mm thick... My little puller is only made for removing R/C engine Cam bearings and with a bit of heat does it well.
Hide Signatures
(in reply to Kmot)
       Post #: 34
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Removing cam bearings from OS engine?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.533RCU1
