WILDHARE 29% EDGE QUESTION
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> WILDHARE 29% EDGE QUESTION
Page: [1]
Login
WILDHARE 29% EDGE QUESTION - 1/24/2008 6:17:10 PM
MetallicaJunkie
Status: online
with in the next week or so i will be buying a v2 50cc edge, id like to know how long the aileron extensions need to be as well as the elevator extensions.
could someone please help me.... i did a search but couldn't find useful info
thanks in advance
e.r.
_____________________________
Freestyle Junkie
Revver Bro #217
       Post #: 1
RE: WILDHARE 29% EDGE QUESTION - 1/24/2008 6:45:38 PM
Tired Old Man
Status: offline
About 18" for the ailerons and 24" for the elevators. Just get 24" to keep it simple and provide some room for locating the receiver. It's 28% btw.
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to MetallicaJunkie)
       Post #: 2
RE: WILDHARE 29% EDGE QUESTION - 1/25/2008 11:55:57 AM
Greg Cothern
Status: offline
You could buy some bulk servo wire and cut the plug off your servo and make the lead exactly the length you need and solder the end back on. NO connections to come apart either..
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
       Post #: 3
RE: WILDHARE 29% EDGE QUESTION - 1/25/2008 9:40:18 PM
MetallicaJunkie
Status: online
i thought about that, its very economical... thanks
Freestyle Junkie
Revver Bro #217
(in reply to Greg Cothern)
       Post #: 4
RE: WILDHARE 29% EDGE QUESTION - 1/26/2008 3:09:05 AM
Greg Cothern
Status: offline
I have done it on my last 3 or 4 birds and it has worked GREAT! Dont have to worry about a connection coming loose, or the pins limiting power to the servo. Takes some of the worrys out of it for me!
       Post #: 5
RE: WILDHARE 29% EDGE QUESTION - 1/26/2008 6:09:17 AM
MetallicaJunkie
Status: online
very true...
what size spinner does the 28% edge use?
Freestyle Junkie
Revver Bro #217
       Post #: 6
RE: WILDHARE 29% EDGE QUESTION - 1/26/2008 6:22:43 AM
Tired Old Man
Status: offline
3-1/2" seems to work out pretty well on the Extra and the Edge.
       Post #: 7
RE: WILDHARE 29% EDGE QUESTION - 1/26/2008 3:56:58 PM
MetallicaJunkie
Status: online
quote:
ORIGINAL: Pat Roy
Thanks pat
do you know if there is a website that has the manual online so i could get a look at it before hand?
Freestyle Junkie
Revver Bro #217
(in reply to Tired Old Man)
       Post #: 8
RE: WILDHARE 29% EDGE QUESTION - 1/26/2008 4:30:04 PM
rctom
Status: online
http://wildharerc.com/downloads/documents/New-Edge-84-detail.pdf
http://wildharerc.com/downloads/documents/generic-manual.pdf
TF
       Post #: 9
RE: WILDHARE 29% EDGE QUESTION - 1/27/2008 4:17:06 AM
MetallicaJunkie
Status: online
thanks tom, i looked on your website and couldnt find it...
i know this is a public forum, and not a place to discuss business, could you PM me or email the shipping estimate to 78537(south texas) and the hardware package price, i also couldnt find that info on your website
Freestyle Junkie
Revver Bro #217
(in reply to rctom)
       Post #: 10
RE: WILDHARE 29% EDGE QUESTION - 1/27/2008 3:35:25 PM
rctom
Status: online
Hardware kit is $75, shipping is about the same or a little less in Texas.
TF
       Post #: 11
RE: WILDHARE 29% EDGE QUESTION - 2/1/2008 12:14:44 AM
MetallicaJunkie
Status: online
i'd like to use robart hinges... this will be my biggest plane yet, my biggest plane a maxxair velox has 1/8 hinges, could i use the same for the 50cc edge or should i use 3/8"?
Freestyle Junkie
Revver Bro #217
(in reply to rctom)
       Post #: 12
RE: WILDHARE 29% EDGE QUESTION - 2/1/2008 1:09:47 AM
rctom
Status: online
The plane comes with 3/16" hinges.
TF
       Post #: 13
RE: WILDHARE 29% EDGE QUESTION - 2/1/2008 5:41:29 PM
MetallicaJunkie
Status: online
thanks Tom... i ordered a 5" bellcrank, would that fit in the 50 cc edge?
Freestyle Junkie
Revver Bro #217
(in reply to rctom)
       Post #: 14
RE: WILDHARE 29% EDGE QUESTION - 2/1/2008 6:10:00 PM
iowadave
Status: offline
I am also assembling an WG 540 edge. I noticed the Pull-Pull rudder control horns are long and limit the movement of the rubber (they hit side of fuse). On my edgs the horn is out about 1 inch from rudder (to outside edge of horn and bolt is even), Has anybody else noticed this and what did you do about it? Will I getting enough movement on the rudder any way? I have not measured the movement of the rudder as I have just installed the horns.
       Post #: 15
RE: WILDHARE 29% EDGE QUESTION - 2/1/2008 6:35:34 PM
raven7usa
Status: offline
First of all, on my WH 540, the bolt that came in the hardware package was 3" long. When you thread the horns on, the center to center distance is about 2 1/2". My servo horn is 3" center to center. So to keep these even, I used a bolt that's 3 1/2" long so as to keep my center to center the same as my servo horn measurment. Make sure your distance's are equal on both ends if your using a pull/pull setup.
Is there 2 holes in the plastic rudder horns? (Memory lapse) If there was, I think I used the inner one and ground off the extra to shorten the horn.
< Message edited by raven7usa -- 2/1/2008 7:15:40 PM >
Run it to the redline. Dieing of natural causes is for sissies.
(in reply to iowadave)
       Post #: 16
