opjose
MD, USA Status: offline
quote:
ORIGINAL: linkadrip IF i fly with the stock ones i'm going to definetly Find some rubber tubing that will fit over them they don't seem to lock. Grommets! I had a bag of grommets from Rat Shack that were perfect for most clevises. The included clevises work fine, but NEVER expand them as far as you might, say plastic clevises from Dubro, as they will break. quote:
ORIGINAL: linkadrip What are you Guys using for the clevises and control rods for the Ailerons?? I used the provided rods and clevises, however I installed Dubro Quick links... yeah I know people say they slip... but the only time I've had one slip was when I failed to put lock tight on them... They sure make it easy to adjust the linkages though. quote:
ORIGINAL: linkadrip Opjose were is your battery located?. Just aft of the canopy, behind my pilot. quote:
ORIGINAL: linkadrip Seems more important to be straight and not cocked to one side or the other. I've place the dowl too far back on a couple of planes and it made almost no difference. The turn radius is not tight on these, but then I don't have to worry about ground loops. You only need a big turn radius to turn the plane around on an average airfield. Consider re-affixing the control wire. quote:
ORIGINAL: linkadrip Definetly going to have to do some expo programing as suggested it would be insane to fly it without any the way it is now. Yeah with the short coupled tail and the good sized control surface it can be fairly hairy the first time if you don't dial in expo. Better to get your plane back down, and have to dial things UP, than to lawn-dart on your first flight....
_____________________________
- Build em'', fly em'', crash em'' and build more.
