opjose
MD, USA Status: offline
Actually there is a thread here on it where we've discussed it's strengths and weaknesses. The red unit has a minor problem in that the struts are not straight. You'll see this when you attempt to build it if you have the red version. To install the upper wing you need to splay them out a bit which introduces a slight BEND to the wood. Over time the wood will accept the warp and the plane is fine, but it is VERY disconcerting when you put the plane together to see this. The orange version corrects this. Otherwise the plane is solidly built but the gear area needs re-inforcement. A high torque mini servo is required for the wings, standard servos elsewhere. Note: Engine Required: 4c 0.52 cu in A standard 2C .46 engine will grossly overpower this plane... ( but a .46 LA will not ). You can use a 2C .32, or .40 standard engine and have plenty of power or even a .46 2C if you really want to go overboard. There is plenty of room in the cowl for any of these engines. In the air the plane is snappy as it is designed to be higherly aerobatic.... so watch your approach speed upon landing and don't pull up quickly on takeoff. I stalled the wings when I maidened it and destroyed my first one. It snap rolls very quickly and loves to tumble in the air when pushed, just like a Pitts. The only hardware I changed out when I built mine were the tail wheel assemblies.
_____________________________
- Build em'', fly em'', crash em'' and build more.
