BillyGoat
MT, USA Status: offline
Kaos1964, your pole barn is like mine with 12’ ceilings. The best type of heat for such a structure is a Gas Infrared Tube Heater. http://www.grainger.com/Grainger/items/7D837 Best thing about heat like this is it heats items in the shop like the floor, workbench, tools, you. It’s completely possible to go out into your shop in the dead of winter, turn on the heat and immediately start working in a tee shirt and be comfortable (as long as your under the heater), even though the thermometer on the wall still reads 30 degrees. With that type of heat it’s not necessary to finish out the inside of your barn, but if you wanted to keep it up to temp all winter long then you certainly would want to. The best place to start would be the ceiling. Steel siding, just like what’s on the outside of your barn, is available for interior applications. It’s a cheaper by the foot than exterior but isn’t treated to battle the elements. Insulating then putting white steel on the ceiling would do wonders. You won’t believe how much brighter your shop will be too. To complete the process you would want to stud out the interior, insulate and sheet the walls. I’ve seen steel used there too but would recommend a sheet product like ply or OSB.
< Message edited by BillyGoat -- 2/12/2008 3:03:42 PM >
