opjose
MD, USA Status: offline
Good job! You touched on most of the build considerations very well. IMHO I find the CMP kits they sell a bit better, while the Evergreen type ARFs require a bit more "fiddley stuff" exactly as you've noted. I also recommend applying a few coats of Top Flite Clear coat after your model is built but before you fly it the first time or run the engine. Remove the canopy or any clear plastic and apply several light coats. This will seal the trim areas from Nitro. Nitro WILL cause the adhesive used to give over time, so if you do not do this you may find the trim and covering coming off. It's a cheap fix needing a few minutes worth of work. Most ARFs from most manufacturers will benefit from this.
_____________________________
- Build em'', fly em'', crash em'' and build more.
