Druss
AB, CANADA Status: offline
quote:
ORIGINAL: Muddin_Mavric well looks like i got it to take a charge. You can go a head and tell me how stupid i am and how little i know about li-po batterys but i hooked it up to my hobbico accu-cycle charger for NiCads and charged it at 500 ma till i got over 9 volts then put it on the esky charger. right now im at 10.7...11.0 volts and climbing on the esky charger. i guess tomarow i will see if its still any good. as long as it makes it a week or two more ill be happy. i was gona order a couple more batterys when i needed to get some parts after i crashed. maybe ill have to get them and maybe a better charger sooner. wow... wow... even after I specifically told you to read up on lipos, because you ruined the first one, you still didn't do any reading. The following is a quote from the hobbico site. quote:
With little more than the press of a button, the Accu-Cycle discharges, charges and conditions NiCd or NiMH cells and packs - while simultaneously measuring and displaying valuable information telling you the condition of your batteries. The following is a quote from the Thunder Power (one of the best known lipo battery manufacturers) safety and instruction sheet found on their website. quote:
Use Lithium Polymer specific chargers only. Do not use a NiCd or NiMh charger - Failure to do so may cause a fire, which may result in personal injury and property damage. PLEASE follow the safe and correct procedures with these batteries. I CANNOT believe that after I had told you that you had ruined your battery, that you should read up on lipos, you would do anything to it without actually reading up on lipos... it just boggles the mind. I specifically stated to throw it out... yes? no? Watch the following video on lipo exposions http://www.youtube.com/watch?v=gSgjj6NT5U8
< Message edited by Druss -- 1/26/2008 9:52:04 AM >
