RE: Build of WACO SRE - Vintage R/C Plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Build of WACO SRE - Vintage R/C Plans
Page: <<   < prev  1 2 [3]
Login
RE: Build of WACO SRE - Vintage R/C Plans - 3/24/2008 10:36:06 PM
kvlasblom
Status: offline
Both the wheel pants are now done.
I just need to make a plywood plate for on the inside, to accept the two screws that hold the wheel pant on the undercarriage.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
WACO Brotherhood #93
Current project: 1/6 WACO SRE build from plans
(in reply to kvlasblom)
       Post #: 51
RE: Build of WACO SRE - Vintage R/C Plans - 3/25/2008 2:09:48 AM
khodges
Status: offline
Beautiful work, as I've said before. They should be a lot more durable than fiberglass pants, worth the extra weight. The finished plane will be something to behold.
I had heard of the Dutch and their wooden shoes, but now your plane has wooden pants.
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
       Post #: 52
RE: Build of WACO SRE - Vintage R/C Plans - 3/25/2008 7:22:38 AM
kvlasblom
Status: offline
Haha!
See the resemblance?
Click for fullsize
(in reply to khodges)
       Post #: 53
RE: Build of WACO SRE - Vintage R/C Plans - 3/28/2008 10:51:50 PM
JoeAverage
Status: offline
I will try to clarify my remarks. By tapered strips I meant the laminating strips shown on the plan for each tip. They are dimensioned that way on the plan. If made a constant width like the similar ones in the second photo, they could be made from the same form ensuring the same shape. As they are shown on the plan, the builder has to make a laminating set-up at each tip.
The pair shown for a 21" cord and must be tapered down at the Trailing Edge on either side and made on a single former and therefore identical.
I mentioned the stringers when discussing detail. I had forgotten that the plans show an external framework and the front is sheeted and scalloped as the Waco Factory Drawings shown in the side view. I plan on adding to this illustrated framework on the exterior to make it more realistic. An opening door covering an access hole would look good. The external framework shown leaves much to be desired but if done nicely I am beginning to think that sheeting the wings may be an real option. I am making 3 of these. If it too heavy sheeted then I'll hang it in the rafters. If one used light balsa and a light fabric to cover it then it may be very possible. I have not used that ply to sheet a wing so I can't comment on it.
As I failed at explaining an alternative method to the copiously time consuming method I generally employ, and seldomly use for a single model, I will try to produce a photo of the alternative method this weekend.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by JoeAverage -- 3/28/2008 11:08:01 PM >
       Post #: 54
RE: Build of WACO SRE - Vintage R/C Plans - 3/28/2008 11:05:04 PM
kvlasblom
Status: offline
quote:
ORIGINAL: JoeAverage
I will try to clarify my remarks. By tapered strips I meant the laminating strips shown on the plan for each tip. They are dimensioned that way on the plan. If made a constant width like the similar ones in the second photo, they could be made from the same form ensuring the same shape. As they are shown, the builder has to make a laminating set-up at each tip.
I mentioned the stringers when discussing detail. I had forgotten that the plans show an external framework and the front is sheeted and scalloped as the Waco Factory Drawings shown in the side view. I plan on adding to this illustrated framework on the exterior to make it more realistic. The external framework shown leaves much to be desired but if done nicely I am beginning to think that sheeting the wings may be an real option. I am making 3 of these. If it too heavy sheeted then I'll hang it in the rafters. If one used light balsa and a light fabric to cover it then it may be very possible. I have not used that ply to sheet a wing so I can't comment on it.
Thanks, I appreciate your efforts for me.
Howcome you're making three? Do you build to sell?
Hope you don't mind me asking...
(in reply to JoeAverage)
       Post #: 55
RE: Build of WACO SRE - Vintage R/C Plans - 3/28/2008 11:18:54 PM
kvlasblom
Status: offline
I don't understand this, sorry. I thought that the stingers shown on the plans already match how it was supposed to be on the real one...
Am I wrong? If so I want to alter that too!
       Post #: 56
RE: Build of WACO SRE - Vintage R/C Plans - 3/28/2008 11:33:09 PM
JoeAverage
Status: offline
I am glad to help if in fact I am. I thank you for starting this thread and motivating me. I do sell models. I don't generally do commissions though. There's not much money in it so I don't want impatient customers. I can't keep them all although I have regretted selling some. I always build more than one of everything, 2 or 3 and I don't fly that much so they would otherwise accumulate. I don't advertise. I don't make all that many but when I sell one the purchaser gets the bragging rights as well for his buck.
       Post #: 57
RE: Build of WACO SRE - Vintage R/C Plans - 3/29/2008 12:32:11 AM
JoeAverage
Status: offline
Here is the best image I have of the stringer detail. If you look at the baggage door you will see the inacurracies of the plan. Adding detail can be like shortening the legs on a chair. It appears that you have the skill if have the desire.
Click for fullsize
< Message edited by JoeAverage -- 3/29/2008 12:37:48 AM >
       Post #: 58
RE: Build of WACO SRE - Vintage R/C Plans - 5/16/2008 6:00:36 PM
kvlasblom
Status: offline
Thanks, I'll be looking into that before I build that stage!
       Post #: 59
RE: Build of WACO SRE - Vintage R/C Plans - 5/16/2008 6:33:32 PM
kvlasblom
Status: offline
One set of wing ribs, for the bottom wing.
Click for fullsize
Click for fullsize
       Post #: 60
RE: Build of WACO SRE - Vintage R/C Plans - 5/16/2008 6:35:13 PM
kvlasblom
Status: offline
One wing tip.
I made the template out of MDF.
Click for fullsize
       Post #: 61
RE: Build of WACO SRE - Vintage R/C Plans - 5/16/2008 7:04:07 PM
kvlasblom
Status: offline
The dihedral braces which run right through the wings, and then I glued the lot together.
Now it's going to take me ages to prepare all the parts for the other half...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 62
RE: Build of WACO SRE - Vintage R/C Plans - 5/27/2008 11:41:13 AM
kvlasblom
Status: offline
The other half of the bottom wings is now also built to the same stage as the right one.
