Optics 6, V-Tail, nose gear
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Optics 6, V-Tail, nose gear Page: [1]
Login
Optics 6, V-Tail, nose gear - 1/29/2008 12:37:58 AM
mbardsley
Status: offline
Ok, was considering getting the Top-Flite Bonanza kit, and have a Optics 6, but want flaps, and retracts, there is my 6 channels, I cant y-cord the rudder servo to run the Nose gear sterring, Any ideas, and keep all my features
       Post #: 1
RE: Optics 6, V-Tail, nose gear - 1/29/2008 4:18:50 PM
Brendan Lugo
Status: offline
Your ailerons will have to run off of 1 channel only (channel #1). Channel 2 and 4 are your v-tail with channel 3 as your throttle, channel 5 as your retract and channel 6 as your flap channel. The ailerons will need to be y'ed to channel 1 and your flaps y'ed to channel 6.
< Message edited by Brendan Lugo -- 1/29/2008 4:19:26 PM >
_____________________________
Hitec RCD
Multiplex USA
(in reply to mbardsley)
       Post #: 2
RE: Optics 6, V-Tail, nose gear - 1/31/2008 1:41:18 AM
molyhotdog
Status: offline
So how does he run the nose gear steering servo?
< Message edited by molyhotdog -- 1/31/2008 1:44:13 AM >
(in reply to Brendan Lugo)
       Post #: 3
RE: Optics 6, V-Tail, nose gear - 1/31/2008 12:07:28 PM
mbardsley
Status: offline
yes, still does not solve the mixing problem on channel 4, which is normaly rudder, since its v-tail, would not have full range of motion to steer.
       Post #: 4
RE: Optics 6, V-Tail, nose gear - 2/1/2008 7:42:25 PM
MikeMayberry
Status: offline
Unfortunately you run out of channels to do what you want. Using a Y harness to run a separate steering servo will not work because it is still affected by the v-tail mixing. The only way to do this is with a 7+ channel radio where you could use a P-mix.
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
       Post #: 5
RE: Optics 6, V-Tail, nose gear - 2/5/2008 5:18:42 PM
molyhotdog
Status: offline
I have a taildragger Cub without ailerons so the rudder/tailwheel is on the right stick. I have flown it and my other four channel planes back to back numerous times so the ground steering with one plane is on the left stick and the other on the right. It has never been a problem.
That being said, I built a KMP V-tail Bonanza and have an Optic. I y'ed off the aileron channel.
(in reply to MikeMayberry)
       Post #: 6
RE: Optics 6, V-Tail, nose gear - 2/5/2008 6:26:31 PM
MikeMayberry
Status: offline
For slow speed stuff that would work, but you would probably want to have the D/R set low so that small adjustments on take off doesn't make you to drag a wingtip!
Mike.
Hitec RCD Rep
(in reply to molyhotdog)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
