RE: ****EXCEED-RC ORDER ISSUE*****    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> RE: ****EXCEED-RC ORDER ISSUE*****
Page: <<   < prev  1 2 3 4 5 [6] 7 8 9   next >   >>
Login
RE: ****EXCEED-RC ORDER ISSUE***** - 9/13/2008 4:13 AM
Evil Ernie
Score: 100
Last Login: 4/14/2009
Status: offline
Wow! Thanks Andy!
You're top notch!!!
quote:
ORIGINAL: yadac123
ok the break arm sent.
Andy
quote:
ORIGINAL: Evil Ernie
Andy,
I think I have the order#. Since there was no packing slip in the box, the only thing that resembles any of the #'s I've seen are 426198.
_____________________________
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety."
Hide Signatures
(in reply to yadac123)
       Post #: 126
RE: ****EXCEED-RC ORDER ISSUE***** - 9/13/2008 5:55 AM
jrock0012
Score: 100
Last Login: 1/30/2013
Status: offline
Hey andy the owners manual says the same thing as the parts page on nitrorcx, it says that the rear axle part # is 81018, but when I ordered that part number I received the pinion gear joint cups which that part number is 81072. On the nitrorcx web page it says rear axles but shows a picture of the pinion gear joint cups?? I've ordered rear axles twice now and received the pinion cups both times, what I need is the rear axles which im guessing is part number 81072 even though it's labeled as pinion gear joint cups on the web page and the manual....if that makes any sense....
Hide Signatures
       Post #: 127
RE: ****EXCEED-RC ORDER ISSUE***** - 9/16/2008 4:00 AM
yadac123
Score: 100
Last Login: 9/17/2010
Status: offline
what's your order number?
Andy
quote:
ORIGINAL: jrock0012
Andy - Official Exceed RC Support Forum Host
Hide Signatures
(in reply to jrock0012)
       Post #: 128
RE: ****EXCEED-RC ORDER ISSUE***** - 9/16/2008 4:16 AM
jrock0012
Score: 100
Status: offline
MY order number is 427665,
Hide Signatures
       Post #: 129
RE: ****EXCEED-RC ORDER ISSUE***** - 9/16/2008 4:33 AM
yadac123
Score: 100
Status: offline
here's a more complete list http://www.exceedrc.com/sparepart51c832.html
can you take a picture of the exact part you need so I can compare.
Andy
Hide Signatures
       Post #: 130
RE: ****EXCEED-RC ORDER ISSUE***** - 9/16/2008 3:05 PM
jrock0012
Score: 100
Status: offline
The pictures on the nitrorcx web site are much more clear, http://www.nitrorcx.com/51c00-81072.html it's labled pinion gear joint cup but these are actually rear axles, rear axles are what I need, thanks andy.
Hide Signatures
       Post #: 131
RE: ****EXCEED-RC ORDER ISSUE***** - 9/17/2008 5:21 AM
Evil Ernie
Score: 100
Status: offline
Andy,
Any Warranty on Exceed vehicles? I had a differential gear assy (08013) get totally stripped out today. Barely two weeks old and less than a gallon of fuel thru it. Needless to say, I'm not really thrilled right now. If this part isn't covered under warranty, then I'll be buying two or three gear assys and a spare full tranny. I know it's a beginner RC, but jeez, I figured I get a little more time out of a gear assy.
So far tho, the engine runs fantastic (I probably just jinxed myself). Starts on the first or second pull and runs really strong.
After I get this fixed, should there be any kind of lube applied or should it run dry? The existing tranny has no grease, oil, or drylube to speak of.
Hide Signatures
       Post #: 132
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 2:34 AM
yadac123
Score: 100
Status: offline
Your order number is 427665 and do you want me to send you 1 x 51c00-81072? this will fix the problem?
Andy
quote:
ORIGINAL: jrock0012
Hide Signatures
       Post #: 133
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 2:36 AM
yadac123
Score: 100
Status: offline
Yes exceed warranty is 30 days. I can help you out. what's your order number?
gear stripped out most of time is the due to crash or lose rock chip get jammed between gear. Please becareful.
Andy
Andy,
Hide Signatures
(in reply to Evil Ernie)
       Post #: 134
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 2:41 AM
jrock0012
Score: 100
Status: offline
Yes I think that would work, they should get this problem resolved though so it doesn't happen to anyone else, thanks Andy
Hide Signatures
       Post #: 135
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 2:44 AM
Evil Ernie
Score: 100
Status: offline
Thanks for the help Andy! My order is 426198. I got the brake assy in the mail today btw. Much appreciated! Hopefully this will be the last time bothering ya!
Come payday, I'll still order a couple extra gear sets and a full tranny just so I have spares on hand.
Hide Signatures
       Post #: 136
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 4:51 AM
yadac123
Score: 100
Status: offline
ok parts sent.
Andy
quote:
ORIGINAL: jrock0012
Hide Signatures
       Post #: 137
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 4:55 AM
yadac123
Score: 100
Status: offline
Done
Andy
Hide Signatures
       Post #: 138
RE: ****EXCEED-RC ORDER ISSUE***** - 9/18/2008 10:08 AM
robausti
Score: 100
Last Login: 5/17/2013
Status: offline
Hello,
Has any one had any trouble with contacting NitroRCX or Raidentech. My issue is that my Forza was returned to them mid Aug 08 and the vehicle has since been out of stock when I did speak to someone they told me they would restock in about 2 weeks now its going on a month and a half.. still nothing. All I have is an RMA number they provided me to return the kit. They did confirm they recieved it but now at this point I want to know what is in stock, and if possible to pay the difference and get something else. When I try calling all I get is a busy signal.
Hide Signatures
       Post #: 139
RE: ****EXCEED-RC ORDER ISSUE***** - 9/19/2008 4:11 AM
yadac123
Score: 100
Status: offline
can you please provide me your order number so I can better help you out.
Andy
quote:
ORIGINAL: robausti
Hello,
Hide Signatures
(in reply to robausti)
       Post #: 140
RE: ****EXCEED-RC ORDER ISSUE***** - 9/19/2008 5:09 AM
jrock0012
Score: 100
Status: offline
Thanks Andy..
Hide Signatures
       Post #: 141
RE: ****EXCEED-RC ORDER ISSUE***** - 9/19/2008 8:31 AM
robausti
Score: 100
Status: offline
Thanks Andy,
My RMA number is 400878.
Hide Signatures
       Post #: 142
RE: ****EXCEED-RC ORDER ISSUE***** - 9/22/2008 8:10 AM
Evil Ernie
Score: 100
Status: offline
quote:
ORIGINAL: yadac123
Done
Andy
Andy,
Quick update on the trans gear failure. I hope to be recieving my parts that you sent and the spares that I bought tomorrow or tuesday. In anticipation, I removed the trans from the vehicle to start the teardown at which time I discovered what caused the failure. The two screws that hold the halves of the trans together were not tight. I thought that maybe this step in the process was missed, but upon further investigation, I found that the holes in the aluminum cross beams were stripped out. Little piles of aluminum powder came pouring out of the holes. This tells me that either the holes were drilled too big and couldn't support the threads, or the tap used to make the threads was shot, or the screws were overtightened and stripped out at the factory.
With the amount of flex that the trans must endure, I'm sure that it twisted/pulled/moved the gear out of alignment. This may have caused the failure and subsequent stripping of the gear. Luckily, I've ordered a complete trans, so I've got it covered until I order new crossmembers. Tomorrow I'll be going over the entire vehicle checking every nut, screw, and bolt.
Thanks again for all your help!!! You da man!!!!
Hide Signatures
       Post #: 143
RE: ****EXCEED-RC ORDER ISSUE***** - 9/23/2008 1:42 AM
yadac123
Score: 100
Status: offline
NP
Andy
quote:
ORIGINAL: yadac123
Done
Andy
Andy,
Hide Signatures
       Post #: 144
RE: ****EXCEED-RC ORDER ISSUE***** - 10/3/2008 11:39 PM
hokiesteven
Score: 100
Last Login: 5/6/2012
Status: offline
Any idea when you will get the diff gear assembly in stock (part #08013)? My order # is yhst-14197398381157-15917. This is my son's first RC (mine as well) and he wants to try it out on a local track in a couple of weeks. Just wondering if he will have the part in time. Thx!
Hide Signatures
       Post #: 145
RE: ****EXCEED-RC ORDER ISSUE***** - 10/4/2008 2:05 AM
yadac123
Score: 100
Status: offline
sorry it's out. Pm me and I'll reply you once I have it in stock.
Andy
Hide Signatures
(in reply to hokiesteven)
       Post #: 146
RE: ****EXCEED-RC ORDER ISSUE***** - 10/4/2008 3:25 AM
Evil Ernie
Score: 100
Status: offline
I've got a couple of those backordered as well.
Andy, any process to specifying what wheel tire combo's we can want? My bud ordered a full set and got old style rims in chrome and blue with herringbone tires. I made another order as well and in the comments box, specified either black or yellow rims. Will that work, or is it a crapshoot?
Hide Signatures
       Post #: 147
RE: ****EXCEED-RC ORDER ISSUE***** - 10/7/2008 6:24 AM
yadac123
Score: 100
Status: offline
Yes it's best to specify color on the comment box and we'll try our best to get what you ask for.
ANdy
Hide Signatures
       Post #: 148
RE: ****EXCEED-RC ORDER ISSUE***** - 10/8/2008 8:58 AM
Indarican
Score: 100
Last Login: 3/29/2011
Status: offline
Andy, Thanks for getting back to me so quickly.I sent you another pm about the pull starter on my infinity. Thanks again for the help. Keith
Hide Signatures
(in reply to usalien)
       Post #: 149
RE: ****EXCEED-RC ORDER ISSUE***** - 10/9/2008 1:54 AM
eggman2112
Score: 100
Last Login: 10/22/2008
Status: offline
Hi,
I was trying to check on my order but there seems to be some confusion.
I have order 434634 yhst-14197398381157-17152 and it was out of stock so i changed the color to sava blue which was in stock via online chat.
I believe someone was supposed to contact me but I haven't heard anything yet. I thought I would try a post here before I start sending emails or calling.
Egg
Hide Signatures
(in reply to Indarican)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.625RCU1
