rckiwi
Joined: 2/7/2007 From: Hamilton, NEW ZEALAND Status: offline
quote:
ORIGINAL: pwaicon Yes, I have the MCD manual that you speak of. The way I look at it, it gives you the stock set up that MCD recommends. I was experimenting with the set up to see how close I could get the 510mm or the 535mm wheelbases used on the MCD’S. I am trying to get close to either one, because I am turning the FS into a rally car and I want to use one of the MCD bodies. I personally think the Peugeot body (the last picture) would look great on the FS. The below pictures shows my current set up which is around 515mm wheel base. If you look at the second picture you will notice the shock fork has a small washer installed to help eliminate the fork and the drive shaft from rubbing. I use this same suspension set up on my MCD, it seems to work the best for me, and I do not need the washer on the MCD (once again this helps illustrated the fit and finish I was referring to in my earlier post). Since we are on the suspension arms, I have a recommendation. The FS uses pins with e-clips on the upper arms I feel this allows for a little slop in the arm. The MCD uses a bolt set up. I will be changing the FS set up and using a bolt with nut instead. I feel this will enable me to tighten up on the suspension arm and thus eliminating the slight movement that now exists. As for the wheel movement I didn’t seem to have any problems with either of the setups I used. I hope I answered your question. Hi Pwaicon, I am converting my FS to Subaru Rally shell and 6 spoke wheels. Did you use the MCD drive cups for the front and rear hubs for the wheels to fit properly? as the FS axles stick out alot further than then the MCD ones would! Cheers
