RE: fs racing 4wd?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: fs racing 4wd? Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: fs racing 4wd? - 6/9/2008 8:45:37 PM
lbsickboy
Status: offline
so you used the original shafts from fs and taped them out thats what i was thinking about doing but was not to sure because the shaft are made from hard steel but now i know that works will be doing that mod to thanks pacrat keep it up this way we will be keeping fs alive and kicking (nice)and now we can give mcd a run for their money soryi should be easy on mcd besause if it was not for mcd we would not have this nice bit off kit in house anyway
so what gear raito are you using now then and what wheels
kleep them s mods coming
_____________________________
a joint aday keeps the dock away in amsterdam
fs mt 4wd kick ass
(in reply to pacrat)
       Post #: 351
RE: fs racing 4wd? - 6/9/2008 8:47:14 PM
lbsickboy
Status: offline
oh sory but did you use a good look tight on thoes studs very importent
fs mt 4wd kick ass
(in reply to lbsickboy)
       Post #: 352
RE: fs racing 4wd? - 6/9/2008 9:02:33 PM
pacrat
Status: offline
Yea use a good lock tight, Also, if you can use a pillar drill it will make life a lot easier, start of with a good quality small drill plenty of lubricant / oil and go up a couple of drill sizes each time, these shafts are HARD just take it nice and steady
       Post #: 353
RE: fs racing 4wd? - 6/9/2008 9:04:59 PM
JQuest64
Status: offline
Here are some of my FS MT. Not quite finished, but getting there. I had to create some of my own rear mounts and trim the body a bit to keep the rear wheels from hitting.
I have the original body as well
(in reply to revopqrs)
       Post #: 354
RE: fs racing 4wd? - 6/9/2008 9:13:03 PM
pacrat
Status: offline
One more thing for you all, if you run the gears 27- 36 and 24 -25 on the buggy you can run fg marder wheels and tires which are bigger in diameter,
they give very good traction, also they increase ground clearence and look well on it!!
[image][/image]
Click to see fullsize image.
Click for fullsize
       Post #: 355
RE: fs racing 4wd? - 6/10/2008 8:59:46 AM
like2race
Status: offline
quote:
ORIGINAL: lbsickboy
Here are some ratios from MCD... in the coloured off road one you have to substitute 19 & 30(old chart) gears for 24 & 25
Hope it helps
I when i get my gears i am going to try some of them out
Cheers
Click for fullsize
Click for fullsize
HPI Baja SS stoker with Rear Dominator - KM Baja with rear upgrade pipe
       Post #: 356
RE: fs racing 4wd? - 6/10/2008 9:03:40 AM
like2race
Status: offline
Now they look Awesome good job mate
(in reply to JQuest64)
       Post #: 357
RE: fs racing 4wd? - 6/10/2008 9:06:28 AM
like2race
Status: offline
quote:
ORIGINAL: pacrat
what kind of hole is the FG gear the same as FS ????
       Post #: 358
RE: fs racing 4wd? - 6/10/2008 3:07:07 PM
lbsickboy
Status: offline
nice paint job looks real where did ye get that from then i wanted one to but they are a bit to high in price for me but when i get one for the right price then im going to paint it flu pink and the fg baja rims to
now all we need is a vid from ye which wold be nice so we are waiting
and thanks for the gear ratios like2race ive seen them on mcdrc .
fs mt 4wd kick ass
       Post #: 359
RE: fs racing 4wd? - 6/10/2008 6:17:14 PM
pacrat
Status: offline
Fg Gears are 10mm inside diameter and will fit straight on to the shafts, lock them on to the flats by the grub screws, then go race!!
(in reply to like2race)
       Post #: 360
RE: fs racing 4wd? - 6/10/2008 9:37:20 PM
lbsickboy
Status: offline
hi pacrat
I've just noticed that your gas pipes are way to close to your gear holder and clutch i think it would be better if you moved them because it can get very hot their and if you go with a alloy gear plate then their will be no plastic around the holding bolts between the clutch and the gear plate so that will get hot to and could melt the tubes when on the run and i don't think that will be a nice experience I'm not telling you that you have to but i would if i was you for your sake and the car
Bernie Bernie ouch boom ha ha told you so
fs mt 4wd kick ass
       Post #: 361
RE: fs racing 4wd? - 6/10/2008 9:55:37 PM
pacrat
Status: offline
Hi lbsickboy
Yea you are right think i should move the fuel lines!
Have you changed the carb yet or have you stuck with the stock one??
       Post #: 362
RE: fs racing 4wd? - 6/10/2008 10:11:23 PM
lbsickboy
Status: offline
hi no i ve still got the same one in it and now with the zen coil and the gear set up 24 39 25 24 and the fg baja rims its prity quick of the mark but i havent had chance for a run yet big test run i mean hopefully this weekend with fs*mt*4wd
fs mt 4wd kick ass
       Post #: 363
RE: fs racing 4wd? - 6/10/2008 10:32:39 PM
pacrat
Status: offline
well if you have the cn30 engine (4 bolt head) try a walbro wt 813 modified carb and a 2 1/2 inch DDM air filter and see the difference!!
really is worth it
