RE: fs racing 4wd?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: fs racing 4wd?
Page: <<   < prev  16 17 18 [19] 20 21 22 23 24 25   next >   >>
Login
RE: fs racing 4wd? - 7/2/2008 12:19:19 PM
Smartechracing
Status: offline
How about the thickness of is plate?
_____________________________
Manufacturer of RC Cars
A member of Perfect international group
(in reply to pwaicon)
       Post #: 451
RE: fs racing 4wd? - 7/2/2008 12:21:28 PM
FS*MT*4WD
Status: offline
so i got some bling in the mail!!
gonna strip em down with drano and polish em up
got it from ken at x rover(ask for the contact)...good price and fast shipping...gave me some extra plastic gears too(not that im gonna need those anymore) oh and i still have not had any problems with my plastic gears...just got these for when they do strip..
(in reply to Mr Terminator)
       Post #: 452
RE: fs racing 4wd? - 7/2/2008 12:50:09 PM
Smartechracing
Status: offline
It's cool man. I want to have one set for my FS, where to buy?
(in reply to FS*MT*4WD)
       Post #: 453
RE: fs racing 4wd? - 7/2/2008 1:10:58 PM
FS*MT*4WD
Status: offline
i got mine from Ken at www. x-rover . com
(in reply to Smartechracing)
       Post #: 454
RE: fs racing 4wd? - 7/2/2008 2:13:06 PM
Smartechracing
Status: offline
       Post #: 455
RE: fs racing 4wd? - 7/2/2008 4:03:33 PM
ea77
Status: offline
Thanks for the tip!
I don't feel like doing a tear down, have limited time to play as it is, so I just play with the car and if something breaks then I'll replace with sealed bearings. I really suspected that they are not sealed because when I ran the car in some slightly moist dirt, the dirt must have worked it way to the steering bellcranks and cause them to practically lock up. I sprayed the steering assembly down with some rust check oil spray (anti corrosive spray) to free the bearings up again.
Some tips I'd like to share with my experience of the car.
1. Re-locktight ALL SET SCREWS on the drive train. Tighten the 6mm set screw from the gearbox outdrive, and 5mm set screws at the drive shafts of the front and rear differentials.
I don't think I was running full time 4WD when I first ran the car a couple of time so it was so-so in performance. Noticed a set screw missing on he drive line. And I began checking all of them.
After relocktite all the set screws in the drive train it was a night and day different. The car took off like a bat out of hell and sounded like a WRC rally car. (high pitch gear whining)
2. Rebuild the shocks.
The included shock oil is terrible. Once the oil heats up, the damping action is reduced. When I tore my shocks down, I was shocked to find that the e-clips holding the shock piston had failed. So I recrimped the e-clip and re-assembled the damper, filled with Losi 30wt oil all around and now the shocks feel great.
3. Locktite the king pin screws on the steering blocks front and rear. These worked loose after a couple of 20 min bash sessions.
I've had the car actually for about 6 mos but haven't run it since a few weeks ago.
quote:
ORIGINAL: FS*MT*4WD
EA77:hey bro, your fs is lookin sweet...how long you had it for??dont forget to change the stock bearings
       Post #: 456
RE: fs racing 4wd? - 7/2/2008 4:15:15 PM
ea77
Status: offline
No videos yet. Maybe in a couple of weeks when my friend comes back we can shoot some.
My goal for this car is just to make the thing run good out of the box.
Oh another mod you NEED is a Outerwears pull start cover. DON'T RUN WITHOUT ONE. I'm so serious on this.
My pull starter from the 30cc motor failed on me after one run, when pulling the rip cord, it did not pull the plastic claws out to grab the fly wheel. Under examination the internal mechanism broken. .
It was flaky from the beginning I could tell because you can pull out 1/3 of the rope before it started to grab onto the flywheel.
So I bought a HPI Fuelie pull starter at a local hobby store as a replacement. Mounted it up and it works perfectly, it's better quality too.
BTW, the spark plug used, TORCH lol or something is a copy of the NGK plug that's used on the CY Fuelie. Replace with NGK Spark Plug CMR7H when it's time.
quote:
ORIGINAL: lbsickboy
hi their ea77 have you got around to making any vids then we would like to see and what other things do you have in mind for the change phase looking good
< Message edited by ea77 -- 7/2/2008 4:17:39 PM >
(in reply to lbsickboy)
       Post #: 457
RE: fs racing 4wd? - 7/2/2008 4:21:33 PM
ea77
Status: offline
Very nice.
We should get a group buy going for these metal gears.
Got a question, seems like you guys have replaced with Hitec 5745 servos. Do these just drop in, or do you need to modify any servo mounts? If there are any modifications can you let me know the details.
I just tried mounting a couple of Hitec 705MG 1/4 servos and the case width isn't as wide as the stock GWS 666 servo, so the mounting servo screw holes don't line up.
Thanks!
quote:
ORIGINAL: FS*MT*4WD
       Post #: 458
RE: fs racing 4wd? - 7/2/2008 4:56:26 PM
FS*MT*4WD
Status: offline
yea i got the mcd servo plate,but some guys on this forum like sickboy made there own supports for the servos,...check the earlier posts on this thread...i think page 5 or 6
(in reply to ea77)
       Post #: 459
RE: fs racing 4wd? - 7/3/2008 8:53:43 AM
like2race
Status: offline
Nice package on the Alloy parts .Good luck on the rebuild
HPI Baja SS stoker with Rear Dominator KM Baja with rear upgrade pipe
       Post #: 460
RE: fs racing 4wd? - 7/3/2008 9:58:34 AM
hellya
Status: offline
here in the USA you can get all the FS alloy parts and cars here http://www.fsracingusa.com/15scaleupgradefittings.aspx
I went to x-rover and all the alloy is sold out http://www.x-rover.com/index.php?main_page=products_new&diorder=6&page=4
< Message edited by hellya -- 7/3/2008 10:03:07 AM >
(in reply to like2race)
       Post #: 461
RE: fs racing 4wd? - 7/3/2008 10:07:05 AM
hellya
Status: offline
quote:
ORIGINAL: Smartechracing
Smartech you might be able to contact a seller/maufacturer in your neck of the woods http://www.fs-racingart.com/index01.php
The website is also in chineese http://www.fs-racingart.com/cn/aboutus.php
I believe this is the manufacturer of FS
Zhejiang Feishen Vehicle CO., LTD
Linkman: nancy Ni Loise Ye
Add: North Lake Road Hardware Science And
Technology Industry Yong Kang City ZheJiang Province
Tel: 86-579-87297156
Fax: 86-579-87270378
P.C.: 321300
Web: www.fs-racingart.com
Email:loise@feishen.com nancy@feishen.com
< Message edited by hellya -- 7/3/2008 10:25:21 AM >
       Post #: 462
RE: fs racing 4wd? - 7/3/2008 5:30:04 PM
Cal-Torque
Status: offline
quote:
ORIGINAL: hellya
What a difference in prices... It's worth waiting for x-rover.
Weird because I think that it was the opposite for stock parts.
Gas Tank
FS Racing - $11.18
X-Rover - $28.00
(in reply to hellya)
       Post #: 463
RE: fs racing 4wd? - 7/4/2008 8:40:32 PM
ea77
Status: offline
Ok I will consider using a mcd servo plate, i test fitted the Hitec 705mg I had on hand with my MCD Baja and the screw holes line up perfectly.
I looked at pg 5-6 and onward and didn't see any information on using the existing servo tray with Hitec 5745 servo. My preference is to use the existing servo tray to save on cost.
quote:
ORIGINAL: FS*MT*4WD
