rckiwi
Joined: 2/7/2007 From: Hamilton, NEW ZEALAND Status: offline
quote:
ORIGINAL: foxy42 Yeh, it does look like the shocks are well setup for traction too. Very little drifting even off power. Good vid rckiwi, looking forward to your next one after tuning. May have been running a bit fat, but certainly sounds like it has some legs at the top end. Is that running with the stock jetpro clone pipe as well? Also, I see you were using a 2.4Ghz radio. Did you change anything else? Servos for example? Hi, In fact I did have another Video of the car once we had run a few tanks though it, but I have lost it some how! Duh!!!! In that vid we had it doing 4WD drifts and easy doing donuts, the Tyres/Tires are verygood for a kit car out of China alot better traction than what I thought they would be. This car was set up only with the Spektrum, but servos were std, but we did have problems with the steering servo coming loose in the mounting, the screws were too small for the hole in the plastic radio plate, new screws solved the problem at the test area. But ideally the steering servo's need replacing with one or two hitec HS-5745 18kg servos would be the best. That test car has been sold and I have one new one left so not sure if I will use that one or sell it as my next order will be sent after Chinese New Year. Cheers Bryan
