i got my fs this weekend apart from the customs im a happy fellow puting new servos in checked every thing a few screws lose but for the rest picobelo so just waiting for the post now for the servos and im off cant wait any one els got one and what are they doing im thinking of getting the fg baja wheels and the asgard body color flu pink and carbon radio tray let me know thanks
_____________________________
a joint aday keeps the dock away in amsterdam fs mt 4wd kick ass
i got me self a mt 4wd if i went 2wd then i could of gone with an other fg and that was not my goal i realy wanted mcd but could not wait so thats the reason for the fs 4wd and a happy fs owner to
Joined: 4/24/2008 From: Great Yarmouth, UNITED KINGDOM Status: offline
Hello Ive just got an fs 4wd touring car from oversize rc. It took a long time coming, but its here so after looking at the car it all seemed ok, but then I started checking, a few things you should look at first - the transmiter is like a kids toy so Ive changed that, next the throttle servo was also no good - very slow and so Ive replaced that, the steering servo screws where to small for the holes - so you could just pull it out. Apart from these points it all seems ok. Oh one more thing the exhaust gasket leaked a little. I ran the first tank of fuel last night - seems ok, but a bit slugesh but havent tuned it yet. The car drives really well and within ten miniuts a crowed had gatherd, anyway Ill let you all know what its like when run in, but if you do get one please check it well first.
< Message edited by hypnopaul -- 4/25/2008 12:17:57 PM >
also the gaskets are ok but you have to tighten them good i prefer the fg gaskets and the wheels their is to much play in the wheel hubs 1.5 mm they fit over the square and that's also why they bend plus the wheel is to to thin going to change them if one breacks
still waiting for the new servos from ddm
Joined: 6/27/2006 From: hamilton waikato, NEW ZEALAND Status: offline
i have just picked up a fs rally car second hand very little use have spent most of the week end doing full strip down and fitting a cy engine regreasing the diffs, replacing shock oil ,adding a second steering servo checking every thing is ok and tight
a few things i found when doing it.. the bearings in the hubs were all shaged cheap china junk will replace the all with good stuff one rear hub had wrong size bearing (center hole was to big for shaft )
apart from that the rest of the car looks good just got to wait till monday to get some new bearings and it will be all go
hi hypnopaul that looks sweet its a good job that you took the servos out it would be apity to reck the car and my bearings were ok but i havent got my servos yet so not a chance to give it a test drive
CA, USA Status: offline
I figured I would share my thoughts on the FS. I picked up a slightly used on road version from a fellow forum member for an excellent price. To be honest I wasn’t really looking for an on road car, but for $450 I had to give it a try. I do own an MCD Baja 1000 and was looking forward to comparing the two. Overall they are very similar, but the FS is not an exact copy. It appears you should be able to use MCD parts on the FS, but when it comes to the drive train, be prepared to change out more than the broken piece, if you choose to use MCD parts for the repair. The FS drive train is identical to the MCD in layout only. The gears are not interchangeable. If you decide to change any component of the FS drive train to MCD you will more than likely have to change another as well. For example if you wanted to use MCD gears, you will have to change all the components on the gear plate to MCD parts. That conversion alone will cost you over $300. Also the gear and pinion used in the FS diff to not mesh and are in the opposite direction compared with the MCD gear and pinion. However, none of that will be an issue if you intend to use FS replacement parts. I decided to completely disassemble the car so I could inspect everything, since others have warned of loose and missing screws. The car is not bad I personally did not find any loose or missing screws. In fact all the screws that had metal to metal contact were a pain in the ass to get loose they used red locktite on everything. In my opinion, the fit and finish on the FS is no where near the quality of the MCD and I have an MCD so I can make this comment. One example is the out put drives on the diff. The FS has a little play in them before you tighten up the set screws and on my MCD there is no play whatsoever. Also the drive shafts on the MCD use a hex shape shaft so the drive blocks do not need set screws. While on the FS they choose not to take this extra step and instead have round shafts which require set screws on the drive blocks. Even some of the fasteners used on the FS seem to strip out a little too easy compared to other cars I have. Those are just an example of the little differences between the two and after owning an MCD, you come to appreciate those little differences. So, speaking on the overall fit and finish of the two vehicles the MCD wins hands down. With that being said, I wouldn’t say the FS is cheaply made, it appears solid. Now let me clarify my statement, when I say it appears solid I am strictly speaking about the car in its rolling chassis form. Does the FS have its flaws? Of course it does, but so does any car you buy. Would I pay $900-$1000 for the FS? No. If I was going to pay that price I would just assume purchase the Cyclone GT for $1150, a much better deal in my opinion. Again with that being said, if you can afford it get the MCD. After owning both I can tell you I have come to appreciate the little and no so little things MCD puts into their vehicles, the attention to details is worth the extra money in my opinion. I have yet to drive the FS car and put it through its paces, so I can not speak on its durability yet. Unfortunately, I will not being testing it in stock form. Since I had it completely apart I couldn’t resist making some changes. For the price I paid, I do not regret purchasing the FS it has been a fun project. I will shoot some video soon and be sure so share it with everyone. The following is a list of changes it did.
-Alloy servo tray (made myself) -Alloy rear tank mounts (made myself) -3 Hitec HS-5745MG servos (went with the double servo steering) -Alloy center diff assembly -Changed to sealed bearing thought -MCD gas cap (example of fit and finish) -Specktrum radio gear -4200 receiver pack -Steel MCD drive gears -8000 RPM high response clutch -DDM 29cc stuffed crank engine -MCD gravel rally tires
< Message edited by pwaicon -- 4/29/2008 1:11:09 AM >
i was also going to do that but you saved me some time anyway just 1? you know the wishbones well according to the mcd manual the red spacers(mcd alloy ones) between the wishbones are on the wrong way just like yours are in the photos or am i wrong i came across this with my mt and the wheels wouldn't turn so i went to the mcd manual and the set up from fs was not right i have changed them around now and now the wheels turn much better the only thing is that the front drive shafts neely touch the shock forks would this be a big issue can you enlighten me on that one please
thanks for your honest review as a current mcd owner
Yes, I have the MCD manual that you speak of. The way I look at it, it gives you the stock set up that MCD recommends. I was experimenting with the set up to see how close I could get the 510mm or the 535mm wheelbases used on the MCD’S. I am trying to get close to either one, because I am turning the FS into a rally car and I want to use one of the MCD bodies. I personally think the Peugeot body (the last picture) would look great on the FS. The below pictures shows my current set up which is around 515mm wheel base. If you look at the second picture you will notice the shock fork has a small washer installed to help eliminate the fork and the drive shaft from rubbing. I use this same suspension set up on my MCD, it seems to work the best for me, and I do not need the washer on the MCD (once again this helps illustrated the fit and finish I was referring to in my earlier post). Since we are on the suspension arms, I have a recommendation. The FS uses pins with e-clips on the upper arms I feel this allows for a little slop in the arm. The MCD uses a bolt set up. I will be changing the FS set up and using a bolt with nut instead. I feel this will enable me to tighten up on the suspension arm and thus eliminating the slight movement that now exists. As for the wheel movement I didn’t seem to have any problems with either of the setups I used. I hope I answered your question.
