like2race
Joined: 4/25/2008 From: Melbourne, AUSTRALIA Status: offline
Pwaicon Excellent thanks for your reply rckiwi Hi, There has been alot of posts on here about the 30cc std engine having no power, I have experimented with them and find if you change the ignition coil they rev out alot harder, use a CY or Zenoah coil. Thanks seems a resonable mod to do I did change the spark plug to a NGK one and seemed to start heaps better as for performace to me its ok but i will try and get the most out of it..thanks for link and part no. Hi, the best servos for your buck are Hitec HS-5745MG 18kg full metal gear, you can get from here in Aus they are also the MCD importer for Aus. http://powerslideracing.com.au/ Very true ..The last i looked they were out of stock no drama i will do a search thanks .Like2race, Yes, I am using 3 Hitec servos. I made the servo tray myself out of a sheet of aluminum I had. However, you could buy one that is made for an MCD I sure it would fit, It may of may not need slight modification. LargeScaleRc sells them they just seem to be out of stock at the moment. You also might want to check any local MCD dealers they might have some as well. Below are the links to LargeScaleRc.com. http://www.innovativehobby.com/index.asp?PageAction=VIEWPROD&ProdID=254 http://www.innovativehobby.com/index.asp?PageAction=VIEWPROD&ProdID=292 Sorry, after reading your post again and someone else’s post I realized you were asking which servos I used and not about the servo tray . I am using 3x HS-5745MG servos, this is the same set up I use in my MCD MT and it works great. Pwaicon ..thanks again no problem will check it out
< Message edited by like2race -- 4/29/2008 12:39:37 PM >
_____________________________
FS Racing 4WD MT 30cc FS Engine, Polished Tuned Exhaust, Zenoah Coil MSD Plug wire & Cap ,TGN Kill Switch
