soundmaster
CO, USA Status: offline
LOL I had the same problem and I tried everything to get them out. I let them sit over night in some rust removal stuff, I tried lithium grease, I mean everything and nothing worked. I finally just drilled the center out of the couple that were stuck cleaned the threads out and then I put new ones in with a medium lock tight on it. After that I could get them off with medium effort after the lock tight set. Hope it helps! Also the MCD bearings fit in there so i got some and put them in and kept the FS ones for backups but make sure you put a little grease on the bearings every now and them i found it helps to keep them cooler and conditions them.
