RE: fs racing 4wd?
Tower Hobbies
Logged in as Guest
Users viewing this topic: kidd
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: fs racing 4wd? Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: fs racing 4wd? - 5/2/2008 9:28:40 PM
bentley marshall
Status: offline
quote:
ORIGINAL: like2race
Bentley Marshall
Great work, looks awesome.. just one thing your car looks too clean
yes it is a bit to clean only just got it all finished yesterday hope to have it out today or sunday for a spin
(in reply to like2race)
       Post #: 151
RE: fs racing 4wd? - 5/3/2008 1:09:54 AM
LARGE-SCALER
Status: offline
All of this discussion is great. I definitely sympathize with the tough decision of FS vs MCD. Honestly, if someone in the USA would have had stock in the FS MT, I would have bought it. They didn't. I chose to contact PRO5thscale and purchased a geniune MCD and I am glad I did. I will not bash anyone else no matter what. Each RCer should do what he/she can afford to enjoy the sport. I will say I am very happy with the sale and service from Pro5thscale. Both Pete and Frank are great to deal with. They don't sell anything that is not quality and I respect that. This MCD is built like a tank. I went with a Zenoah engine and Jet Pro pipe. I hope to post some pics and vids after a while. Go large scale!!
(in reply to bentley marshall)
       Post #: 152
RE: fs racing 4wd? - 5/3/2008 2:41:08 AM
like2race
Status: offline
Sounds like an Awesome package i wouldnt mind it at all , can you share a price.. but i think the $ will scare me
would be great to see your pics as well have a ball driving it mate
Cheers
_____________________________
FS Racing 4WD MT
30cc FS Engine, Polished Tuned Exhaust, Zenoah Coil MSD Plug wire & Cap ,TGN Kill Switch
(in reply to LARGE-SCALER)
       Post #: 153
RE: fs racing 4wd? - 5/3/2008 3:08:01 AM
jzemaxx
Status: offline
What is the weight of the FS 4wd touring car? Also what is the wheelbase, I haven't seen that mentioned in the specs.....
       Post #: 154
RE: fs racing 4wd? - 5/3/2008 5:25:46 AM
mikeinoz
Status: offline
quote:
ORIGINAL: like2race
Cheers
Best you contact the Aussie MCD dealers, www.powerslideracing.com.au
       Post #: 155
RE: fs racing 4wd? - 5/3/2008 10:45:18 AM
like2race
Status: offline
mikeinoz thanks mate i have been to their site all good
Any one got a comment on wheather the high octane fuel 95-98 is better to use or standard 92 oct mixed fuel on the 2 stroke engines
I have bought 5 litres 98 octane put fuel conditioner in and then mix 600ml when needed with fuchs silkolene comp 2 plus 2T oil 25:1
i figure use a good oil but not sure if the fuel 98 octane is overkill or of no benifit
any comments ?
Cheers
FS Racing 4WD MT
(in reply to mikeinoz)
       Post #: 156
RE: fs racing 4wd? - 5/3/2008 11:10:11 AM
bentley marshall
Status: offline
i use 96 on all my cars and boats and mixed at 40:1
       Post #: 157
RE: fs racing 4wd? - 5/3/2008 11:16:41 AM
hellya
Status: online
I use coleman @ 33:1 or 4oz of 2 cycle per gallon of coleman
< Message edited by hellya -- 5/3/2008 11:22:13 AM >
       Post #: 158
RE: fs racing 4wd? - 5/3/2008 5:32:07 PM
pwaicon
Status: offline
The toe-out sounds normal to me. When you apply the brakes the front on the tuck noise dives and this is what is causing the tires to toe-out. I wouldn’t worry about it, especially if it is only occurring when you apply the brakes.
(in reply to lbsickboy)
       Post #: 159
RE: fs racing 4wd? - 5/3/2008 6:32:10 PM
lbsickboy
Status: offline
thanks very much like i said its all new and fxxxxxx great im loving it saving up for the up grades alloy gear plait and the 4 metal gears and the alloy bearing holders 3 of.Not to sure if ill go with the fs or mcd money money money and all so thinking about the fs wheel hubs front and back and for all the front ones they tack a lot of shxt
thanks again
a joint aday keeps the dock away in amsterdam
fs mt 4wd kick ass
(in reply to pwaicon)
       Post #: 160
RE: fs racing 4wd? - 5/5/2008 11:45:00 AM
like2race
Status: offline
I have had a bit of drive on the weekend all went good and nothing broken Engine seems to be running great the more runs i do...But !!
I noticed my front wheel bearing hub on one side was hot so i thought i better see about changeing the chinese bearings
Now jeezes i cant get the square wheel drive that goes into the wheel with the two grub screws in it off .i used an impact driver i used and bent an allen key!! far out bent the crap out of it... WHATS THE SECRET are they left handed or just loctited ANY ADVICE how to get them off would be appreciated
also can any one point me in the right direction to the best place for bearings
Cheers
FS Racing 4WD MT
       Post #: 161
RE: fs racing 4wd? - 5/5/2008 3:01:03 PM
lbsickboy
Status: offline
hi i hade the same its just the locktight dont worry take the wheel hub of put it in the vice get a pair of molegrips put a little heat on the wheel square and put the mole grips on the drive shaft and gently turn and it should come loose dont fot get the grub screws to loosen them
fs mt 4wd kick ass
       Post #: 162
RE: fs racing 4wd? - 5/5/2008 6:00:29 PM
soundmaster
Status: offline
LOL I had the same problem and I tried everything to get them out. I let them sit over night in some rust removal stuff, I tried lithium grease, I mean everything and nothing worked. I finally just drilled the center out of the couple that were stuck cleaned the threads out and then I put new ones in with a medium lock tight on it. After that I could get them off with medium effort after the lock tight set. Hope it helps!
Also the MCD bearings fit in there so i got some and put them in and kept the FS ones for backups but make sure you put a little grease on the bearings every now and them i found it helps to keep them cooler and conditions them.
       Post #: 163
RE: fs racing 4wd? - 5/5/2008 6:17:39 PM
lbsickboy
Status: offline
hi soundmaster how are the mcd bearings holding up then because those things do get very hot indeed ive gone threw 4 2 on the inside + 2on the out side front ones im talking about and you
fs mt 4wd kick ass
(in reply to soundmaster)
       Post #: 164
RE: fs racing 4wd? - 5/5/2008 7:59:03 PM
soundmaster
Status: offline
They do get hot even the MCD tend to but i always squirt a little lithium white grease on them before i run and it help tremendously it is about a 20 degree differance. I tested them with a temp gauge. Any metal on metal should have some lubrication on it. It is a bit more matinence on it but it saves you money in the end. I always make sure the diffs are lubed, bearings, motor gears each time before i race. If i am bashing and messing around i just lube the berings up a bit.
       Post #: 165
RE: fs racing 4wd? - 5/5/2008 8:03:22 PM
soundmaster
Status: offline
Also running at full speed long streaches multiple times also heats things up a lot. If you have a on-road car and are doing oval racing the more you lube the better beacuse those long full speed runs are hell on those parts. If you have a monster truck and run a lot at full speed it will do the same thing so play with some diffrent lube and greases and see what they do and how your car performes.
       Post #: 166
RE: fs racing 4wd? - 5/5/2008 8:09:45 PM
lbsickboy
Status: offline
thanks for the tip mucker wil do that i only go bashin
oh and ive just took the back end diff case apart looks good bearings in good shape and the diff case i got some silicone kit and put that between the diff case +shaissi and put more grease in their to help a little bit for the helical gear their was not much on them so i
