RE: fs racing 4wd?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: fs racing 4wd?
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: fs racing 4wd? - 5/7/2008 2:24:20 PM
Foxy
Status: offline
quote:
ORIGINAL: hellya
quote:
ORIGINAL: like2race
I have had a bit of drive on the weekend all went good and nothing broken Engine seems to be running great the more runs i do...But !!
I noticed my front wheel bearing hub on one side was hot so i thought i better see about changeing the chinese bearings
Now jeezes i cant get the square wheel drive that goes into the wheel with the two grub screws in it off .i used an impact driver i used and bent an allen key!! far out bent the crap out of it... WHATS THE SECRET are they left handed or just loctited ANY ADVICE how to get them off would be appreciated
also can any one point me in the right direction to the best place for bearings
Cheers
A soldering iron heated up.... then held it to the grub screw for 30 sec to a min will make the locktite lossen up[ ]
Yep, except I'd change that for 30mins to an hour with a soldering iron. Get yourself a gas pentorch. Indispensible tool in this hobby. Make that grub screw very hot in a matter of seconds.
_____________________________
Foxy. RCU Car Forums Moderator.
These opinions are my own and may not represent the views of RCUniverse.com
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to hellya)
       Post #: 176
RE: fs racing 4wd? - 5/7/2008 5:08:02 PM
lbsickboy
Status: offline
thanks oh the wheels they are from make carson i bought from hobby-tech in germany real cheap i had them on my fg mt and still going good so i thought i would take the fs wheels of and put them on the fs and boy it dose the job pretty happy im now thinking of using my fg baja wheels and then with a asgard baja 1ooo body
also spoke to a friend and asked him if he could make me the fs mt wheels from alloy and that's no probs so thats also an option but make them a little smaller so i don't have to cut the chassis i will let yopu know
a joint aday keeps the dock away in amsterdam
fs mt 4wd kick ass
(in reply to like2race)
       Post #: 177
RE: fs racing 4wd? - 5/7/2008 5:16:49 PM
lbsickboy
Status: offline
yep ive got one already it works a treat you cant go with out it
also about the lock tight their is now stick form and different types of uses check here harry is his name and bean in the game for as long as i can remember fg dealer holland http://www.pitstop-shop.nl/ go to materials all the info you need about this
fs mt 4wd kick ass
(in reply to Foxy)
       Post #: 178
RE: fs racing 4wd? - 5/7/2008 6:20:00 PM
hellya
Status: offline
quote:
ORIGINAL: Foxy
quote:
ORIGINAL: hellya
quote:
ORIGINAL: like2race
Cheers
Thats funny....I used the iron on my firehammer wheels squares it worked fine no 30 min ....[)]
(in reply to Foxy)
       Post #: 179
RE: fs racing 4wd? - 5/8/2008 12:03:27 PM
like2race
Status: offline
We seem to all be on the same page HEAT is the key the more you apply the quicker it works ..
Anyways this week i received my
polished FS exhaust pipe
zenoah coil
hitec hs5745 mg steering servo
May have time over the weekend to install hopefully
I was thinking of making a stainless servo plate say 1.5 -2 mm thick and liquid nail and screw on top of the existing servo plate thats there
to take the 2 hitec servos. at the moment i have one Hitec installed and i used the damaged gws as a dummy on the other side to take up some of the steering slack and side forces(removed the gears inside).anyways will give it bit more thought
I havent got the gear to do the awesome job that pwaicon done ...but then again still thinking
< Message edited by like2race -- 5/8/2008 12:04:51 PM >
FS Racing 4WD MT
30cc FS Engine, Polished Tuned Exhaust, Zenoah Coil MSD Plug wire & Cap ,TGN Kill Switch
       Post #: 180
RE: fs racing 4wd? - 5/8/2008 1:02:29 PM
xNightWolfx
Status: offline
i want to convert my 2 wheel to 4 wheel
but first thing is im gettign the fs alloy gears
there on order now due onthe 16th
       Post #: 181
RE: fs racing 4wd? - 5/8/2008 3:54:59 PM
lbsickboy
Status: offline
hi
when the fs pipe comes check for holes before you place it on the motor because i had 2 one half way down and the other under at the end (all the welds) what you can do is put a stop in either end air tight but at one end make sure you leave a hole just big enough so you can connect a compressor and get some washing up liquid with water and brush it over the welds and you should see if it leaks
the rest you know
by the way which one have you orderd
fs mt 4wd kick ass
       Post #: 182
RE: fs racing 4wd? - 5/8/2008 3:58:19 PM
lbsickboy
Status: offline
hi try here say lee sent you (sickboy) hes good to deal with and cheap he can get all the parts you want http://www.x-rover.com/
fs mt 4wd kick ass
(in reply to xNightWolfx)
       Post #: 183
RE: fs racing 4wd? - 5/9/2008 4:14:25 AM
Cal-Torque
Status: offline
quote:
ORIGINAL: lbsickboy
Is that guy reliable? His prices are pretty sharp. Does he have stuff in stock, or is it all drop ship?
(in reply to lbsickboy)
       Post #: 184
RE: fs racing 4wd? - 5/9/2008 4:30:00 AM
hellya
Status: offline
I bought 2 KM bajas from him on ebay
its drop ship but he must have a good contact beause I recieved my first 1 about 6 days after the auction the second 1 took 8 days
its not a 30 day wait like some other company I wont mention
< Message edited by hellya -- 5/9/2008 4:32:25 AM >
(in reply to Cal-Torque)
       Post #: 185
RE: fs racing 4wd? - 5/9/2008 4:35:32 AM
Cal-Torque
Status: offline
quote:
ORIGINAL: hellya
Try 60, and I never did get the extra parts that I was promised.
But, I'm not bitter.
       Post #: 186
RE: fs racing 4wd? - 5/9/2008 9:24:43 AM
like2race
Status: offline
Hi Thanks for the tips all was ok no holes Got it from Kooltoyz awesome quick service
could have done with a new gasket just applied some muffler putty to be sure but all installed and sounds awesome.
The ignition came in also from DDM excellent service also but did not have the spark plug boot (will try and find one tommorow.)
Cheers
FS Racing 4WD MT
       Post #: 187
RE: fs racing 4wd? - 5/9/2008 9:28:10 AM
like2race
Status: offline
I think its all way Overrated
FS Racing 4WD MT
       Post #: 188
RE: fs racing 4wd? - 5/9/2008 11:25:59 AM
rckiwi
Status: offline
Overrated RC is that!
They tried to sell there stuff here but soon got squashed!! hehe!
Kooltoyz are awesome to deal with!
Like2race I would email DDM as it should have come with a cap!
