thunder tiger steering a balance help please !!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> thunder tiger steering a balance help please !!
Page: [1]
Login
thunder tiger steering a balance help please !! - 1/29/2008 10:25:54 PM
ntc388
Status: offline
can anyone help me with my bike, im new to rc bike . my bike is not balance at all and keeping getting flip over . im using a JR stander servo, and a 17 turn motor . any help ??/ thankz!!
       Post #: 1
RE: thunder tiger steering a balance help please !! - 1/30/2008 10:33:00 AM
bikeracer
Status: offline
Just as in full size,the bike needs some forward momentum before it'll balance,so give it a push.
The steering also needs to be reversed,that is when you steer left on your TX the front wheel wants to point as if it's turning right and vice versa.Bikes steer by leaning and not pointing the wheel in the direction you want to go,so if you point the front wheel to the right,the bike will lean over to its left hand side.
(in reply to ntc388)
       Post #: 2
RE: thunder tiger steering a balance help please !! - 1/30/2008 7:14:19 PM
ntc388
Status: offline
thankz alot . but also even i gave a a push it run for like 20 feet its still flip over . and the steering i did like you said like the bike its lose control . i think im go for the high torge servo . thankz again!! for your help
(in reply to bikeracer)
       Post #: 3
RE: thunder tiger steering a balance help please !! - 1/31/2008 9:59:11 AM
bikeracer
Status: offline
A pic of your steering set up would help.
If you've got a direct connection without some form of springs or fuel tube fitted from the servo to the forks you will have problems.
       Post #: 4
RE: thunder tiger steering a balance help please !! - 2/1/2008 5:35:38 AM
splcrazy
Status: offline
hey im having the same problems lol and i almost was turning it properly in the end but the steering servo is just too weak and slow and adjusting it on the controller doesnt help
       Post #: 5
RE: thunder tiger steering a balance help please !! - 2/1/2008 9:08:30 AM
bikeracer
Status: offline
A standard servo is adequate on the steering if you're only bashing.
The servo only initiates the lean,the throttle does the turning.
That is,if you try to turn on full throttle you'll only be able to do wide turns.It's no problem to turn a bike through 180 degrees in about ten feet when you master throttle control,just forget anything you learned about steering cars,it's not the same for a bike.
The faster you go the harder it is to get a bike to turn or change direction.Adjusting the steering rake or the spring tension on the servo rod will affect how nimble the bike is.
(in reply to splcrazy)
       Post #: 6
RE: thunder tiger steering a balance help please !! - 2/1/2008 4:43:17 PM
ntc388
Status: offline
thankz alot bikeracer i still need the crash kit seen i bought it for $60, the guys sale it to me dont know where he put it ,
       Post #: 7
RE: thunder tiger steering a balance help please !! - 2/1/2008 6:14:00 PM
bikeracer
Status: offline
No idea what a crash kit is,but if you mean the wire sliders that stick out of the side,just bend some up from piano wire.
       Post #: 8
RE: thunder tiger steering a balance help please !! - 2/4/2008 8:55:01 PM
stubbyphilips
Status: offline
The bikes don't need a lot from the servo. You can get away with the cheapest lightweight servo and still get good input to the steering.
You really want the front end to flop from side to side when you grab the bike and shake it.
The next thing to do is make sure the front end is real straight without adjusting the trim on your transmitter.
Then you will want to back the transmitters steering endpoints til you just get the front to move side to side. After you get the hang of it you will readjust the endpoints.
Now give it a try, just remember the bikes won't turn very sharp when they are going fast and if the front end just plows on you let go of the steering after you initiate your turn.
If you look up Benwell racing on the web they have one of the best tutorials for setting up the bikes and understanding how to steer them that I have ever read.
And if all else fails we can meet at NORCAL and I will show you how to setup one of these beasts.
Here is the benwell page
http://www.teambenwell.uklinux.net/part1.pdf
< Message edited by stubbyphilips -- 2/4/2008 9:08:05 PM >
       Post #: 9
RE: thunder tiger steering a balance help please !! - 2/12/2008 8:16:01 AM
whitham69
Status: offline
do you have the trianglor tyre on the front?
(in reply to stubbyphilips)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
