Rustler VXl Battery & charger!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MaxAmps Support >> Rustler VXl Battery & charger!
Page: [1]
Login
Rustler VXl Battery & charger! - 1/29/2008 11:13:27 PM
triggerfreak
Status: offline
What is a good battery and charger set up for the rustler vxl truck.I do not want lipo.I would like to be able to charge the battery quickly and maybe 2 at a time.I am looking for batterys that give me some descent speed but the longest run times possible.I don't know much as i have only had what the hobby store has sold me, which was a standard ac/dc charger and like a 6 cell 2400 battery for my emaxx.I don't know if i could use 7 or 8 cells and like 4600 or 500o mah.Thanks!Also a good place to purchase some of your products as i have heard good things.
< Message edited by triggerfreak -- 1/29/2008 11:14:58 PM >
       Post #: 1
RE: Rustler VXl Battery & charger! - 1/31/2008 9:25:15 PM
JAM MaxAmps
Status: offline
This link will take you to all of the packs both NimH and Li-Po that will work with your rustler. http://www.maxamps.com/products.php?cat=75 And this link will take you to a charger that will charge two 7 cell packs at the same time with a series adapter. http://www.maxamps.com/Eos6i-AC-DC.htm and the series adapter that will allow you to charge two 7 cell packs as a 14 cell pack. http://www.maxamps.com/proddetail.php?prod=Traxxas-Series-Adapter&cat=78 make sure you order your packs with the Traxxas connector and request one for the Charger leads when you order.
Jason
< Message edited by JAM MaxAmps -- 1/31/2008 9:26:34 PM >
_____________________________
Jason
MaxAmps Marketing Manager/Tech Support
(in reply to triggerfreak)
       Post #: 2
RE: Rustler VXl Battery & charger! - 3/26/2008 2:58:46 PM
vxlstampede king
Status: offline
If i upgraded to the vxl from my traxxas stampede would a 9 cell hump pack fit in it? And what charger would i need for a 9 cell 4700 mah?
(in reply to JAM MaxAmps)
       Post #: 3
RE: Rustler VXl Battery & charger! - 3/26/2008 3:04:24 PM
JAM MaxAmps
Status: offline
Yes the 9 cell will fit in it and the Hyperion EOS0606i AC/DC will charge up to 14 cells NimH.
Jason
Jason
(in reply to vxlstampede king)
       Post #: 4
RE: Rustler VXl Battery & charger! - 3/26/2008 3:09:06 PM
vxlstampede king
Status: offline
How fast will that charger charge that battery because i need quick charging time?
       Post #: 5
RE: Rustler VXl Battery & charger! - 3/26/2008 3:11:47 PM
JAM MaxAmps
Status: offline
It will charge that pack at 4.7 amps so about 80 to 90 minutes.
Jason
Jason
       Post #: 6
RE: Rustler VXl Battery & charger! - 3/26/2008 3:13:44 PM
vxlstampede king
Status: offline
do you know of any faster chargers that will charger it in like 45 min?
       Post #: 7
RE: Rustler VXl Battery & charger! - 3/26/2008 3:18:41 PM
JAM MaxAmps
Status: offline
What your talking about doing will only ruin the packs. Not only that but you risk overheating the cells and this could cause a fire or an explosion.
Jason
Jason
       Post #: 8
RE: Rustler VXl Battery & charger! - 3/26/2008 3:20:39 PM
vxlstampede king
Status: offline
Ya i think i will stick with that one charger that you recomended
       Post #: 9
RE: Rustler VXl Battery & charger! - 3/26/2008 3:22:56 PM
JAM MaxAmps
Status: offline
Just buy two or three packs that way you run one, ones ready and the other can be charging.
Jason
Jason
       Post #: 10
RE: Rustler VXl Battery & charger! - 3/26/2008 3:24:54 PM
vxlstampede king
Status: offline
Now have you seen those charger that charge 2 batteries at a time how efficent are those?
       Post #: 11
RE: Rustler VXl Battery & charger! - 3/26/2008 3:37:49 PM
JAM MaxAmps
Status: offline
with the proper power supply that can do 360 watts the 0610i DUO we have is very efficient. The 0606i will do two 7 cell packs in series as a 14 cell with no problem.
Jason
Jason
       Post #: 12
RE: Rustler VXl Battery & charger! - 3/26/2008 3:49:18 PM
vxlstampede king
Status: offline
How about hobbico chargers are those any good?
       Post #: 13
RE: Rustler VXl Battery & charger! - 3/26/2008 3:56:31 PM
JAM MaxAmps
Status: offline
If you want the best I recommend the Hyperion Line. I can't comment on any other brands.
Jason
Jason
       Post #: 14
RE: Rustler VXl Battery & charger! - 3/26/2008 3:58:46 PM
vxlstampede king
Status: offline
ok do any of your twin charger have a ac and dc power source ?
       Post #: 15
RE: Rustler VXl Battery & charger! - 3/26/2008 4:00:55 PM
JAM MaxAmps
Status: offline
Nope the only AC/DC is the EOS0606i the others are all DC only.
Jason
Jason
       Post #: 16
RE: Rustler VXl Battery & charger! - 3/26/2008 4:02:28 PM
