Downthrust on Extra 300 38%
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> Downthrust on Extra 300 38%
Page: [1]
Login
Downthrust on Extra 300 38% - 1/31/2008 7:42:08 PM
danielwidman79
Status: online
Hello
Im just going to tighten the bolt to the DA on the 28% Extra 300.
Should i put washers between engine and firewall to get more downthrust?
       Post #: 1
RE: Downthrust on Extra 300 38% - 1/31/2008 9:15:57 PM
rctom
Status: offline
Why would you think this is a good idea?
TF
(in reply to danielwidman79)
       Post #: 2
RE: Downthrust on Extra 300 38% - 1/31/2008 10:37:52 PM
krayzc-RCU
Status: offline
sounds like u have not flown this bird yet.. If so fly it and then come back to correct issues to fit your needs ie, CG then thrust issues right and up is what find a brid needs from time to time....
_____________________________
smooth as silk!
(in reply to rctom)
       Post #: 3
RE: Downthrust on Extra 300 38% - 1/31/2008 10:57:30 PM
Tired Old Man
Status: offline
You cannot know what type of thrust angles will be needed until the plane is flown. As Krayzc noted above, you have several things to do before you finalize any thrust angles. Balance and trims work together to make number one. Once the balance is out of the way and the plane flys at near neutral trims at medium throttle settings you can start determining what thrust angles, if any, will be needed. Does the plane nose up when you cut the throttle? Then you need less down thrust, and vice versa. After the engine vertical thrust line is done you can go to work on right thrust. One thing at a time.
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to krayzc-RCU)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.361RCU1
