vnmsgt
FL, USA Status: offline
Well I just got a K8T RTR in stock and 2 Pro kits. First RTR I have seen with my own eyes. I am very impressed with the quality of the RTR. Shock towers are thick! Looks like 4mm but will measure to make sure. Comes with a rechargeable glow ignitor, and Force .25 motor in it too. Only thing you would have to change of you are going to race are the tires, they are a little soft. Servo's seem decent and the radio has trim adjustments and thats about it but most people will upgrade to a spektrum anyways. Chassis braces are thick plastic but are adjustable in center with a turnbuckle to apply more stiffness if needed. All the shock towers, radio tray, diff top plate and steering plate look CNC and not a pressed aluminum like on cheaper truggies. All turnbuckles are the same thickness as the kit model too so they do not have to be upgraded for racing or more durability like on most RTR's compared the kits of the same truck. Very well built RTR!
_____________________________
CASTER RACING K8T, ZX-1R, Fusion EX-1 HOLESHOTHOBBIES, GO TECH, AVID BEARINGS, Don''t jump on the bandwagon...CRUSH IT
