mrbigg
IL, USA Status: offline
quote:
ORIGINAL: bob27s MrBigg... The standard Jett-Stream .46 size muffler, JS-40-TT (OS/TT bolt pattern). I have been playing with the OS55 a bit myself. VERY nice engine. Dub has found that it runs well too. Our test data is pretty much in line with what Ed found in his OS55/Jett combo. The engine has been impressive. Key I found is the engine runs at its best when propped to run between 13,500 and 15,000 peak ground rpm (with the stock muffler, or the jett muffler). It runs ok loaded down a bit more, but this is the rpm band where it seems to develop its best power. Does run ok with the stock muffler when loaded down a bit more, and fuel delivery does not seem to be an issue. Thanks Bob.
_____________________________
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
