RE: O.S. 55AX thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: O.S. 55AX thread
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: O.S. 55AX thread - 6/28/2008 4:47:04 AM
Ed Cregger
Status: offline
Nowhere does it say that the .55AX is designed to lug large propellers. Not like a .61 SF or RF is designed to lug large pattern props.
When talking to the crew at Jett Engineering, I was told not to exceed an 11x6 when using their primo power boosting muffler. I suspect that they know a bit more about engines than the marketing folks that wrote the US OS operator's manual. Lots of importers write their own manual for various engine brands.
One reason they (US importers of OS) might not favor smaller props is because they know that, unlike previous OS two-strokes, the OS.55AX connecting rod's upper end is not bushed. Had I known this fact before purchasing, I would not have bought them. This is flat out cheap construction. Perhaps they will wise up and eventually offer a connecting rod that is properly bushed on both ends.
I would try an 11x7, or even an 11x6 when not using a high performance muffler, such as the Ultrathrust or Jett muffler (never can remember its name). Using one of the high performance mufflers or a pipe, I would use an 11x6 or lesser prop (10x7 or 10x8). Remember, the .55AX is just a glorified .46AX, not a shrunken .61FX.
Without the bushing in the connecting rod's wrist pin end, you MUST use a fuel with at least a smidgeon of castor oil, or the upper end is going to go oblong on you.
Ed Cregger
_____________________________
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
(in reply to jeffk464)
       Post #: 76
RE: O.S. 55AX thread - 6/28/2008 6:46:46 AM
STICK MODE
Status: offline
Have to agree with you there Ed i have mine in a ultrasport and having a low ground clearence tryed a 3 bladed prop in 12x5 results it wouldent rev out then went to a 11x6 revs jumped by 1500 HUMM like you i wish i had bought the old 46AX and that carb setting which is off set is a pain hard to fit in a small place might save a few fingers but as we know you only fight with the prop once lol =steep learning curve
< Message edited by blw -- 6/30/2008 3:21:09 PM >
"The two most common elements in the universe are hydrogen and stupidity"
(in reply to Ed Cregger)
       Post #: 77
RE: O.S. 55AX thread - 6/28/2008 9:11:06 AM
bgee
Status: offline
thesouth1, just wondering what brand pitts muffler you used? and do you have any pics?
(in reply to STICK MODE)
       Post #: 78
RE: O.S. 55AX thread - 6/30/2008 2:16:41 PM
thesouth1
Status: offline
I used the Bisson Pitts avaiable from:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=001155697&I=LX8680&P=K
As for pictures:
Buy the ticket, Take the ride.
(in reply to bgee)
       Post #: 79
RE: O.S. 55AX thread - 9/1/2008 3:30:18 AM
Jetmutt
Status: offline
Hello theSouth1,
I was reading thru this OS55 thread saw the the picture of that very nice looking plane of yours. Can you tell me what aircraft this is and where I can find one. Thanks
(in reply to thesouth1)
       Post #: 80
RE: O.S. 55AX thread - 9/1/2008 5:29:15 AM
flyingbells
Status: offline
Does the 55AX has the same bolt pattern of a 46FX?
(in reply to Jetmutt)
       Post #: 81
RE: O.S. 55AX thread - 9/1/2008 5:58:45 AM
DarZeelon
Status: offline
quote:
ORIGINAL: flyingbells
Does the 55AX has the same bolt pattern of a .46FX?
FB,
That's an affirmative.
The OS.55AX was designed to be a drop-in replacement for all other late-model OS.40-.50 ball-bearing engines, including the SF/RF/VF and FSR/VR.
It will not fit instead of the OS.40/.46LA/FP, however (bronze bushed engines)...
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - Nelson - Bolly - Mejzlik
(in reply to flyingbells)
       Post #: 82
RE: O.S. 55AX thread - 9/1/2008 9:59:28 PM
mk1spitfire
Status: online
surley castor oil, as well as blackening your engine, will gum up and destrroy your engine.
Weve moved on from the castor bean!
(in reply to DarZeelon)
       Post #: 83
RE: O.S. 55AX thread - 9/1/2008 10:44:56 PM
Broken Wings
Status: offline
quote:
ORIGINAL: mk1spitfire
ROFLMAO!!!!!!!!
Regards,
John
(in reply to mk1spitfire)
       Post #: 84
RE: O.S. 55AX thread - 9/1/2008 11:10:42 PM
mk1spitfire
Status: online
Nice model, what is it?
       Post #: 85
RE: O.S. 55AX thread - 9/2/2008 6:12:58 PM
MarvinE255
Status: offline
The os parts list shows the rod to be the same as the one used in the OS 50sx wkich is bushed on both ends.
DOC
       Post #: 86
RE: O.S. 55AX thread - 9/2/2008 6:49:18 PM
liquid_TR
Status: online
You may have moved on, but rest assured, we are still here (and I bet we will be here for a much longer time )
LiQuid TR
       Post #: 87
RE: O.S. 55AX thread - 9/2/2008 6:55:48 PM
mk1spitfire
Status: online
Not, if they castor been plant gets a disease or gets wiped out for logging.!!!!!!!!!!
< Message edited by mk1spitfire -- 9/2/2008 6:56:08 PM >
(in reply to liquid_TR)
       Post #: 88
RE: O.S. 55AX thread - 9/2/2008 9:31:12 PM
Strykaas
Status: offline
Just in case you haven't heard of it, Castrol has stopped producing the well known and used "Catrol M" castor based oil (dedicated to model engine use). It definitely proves that castor based oils are less used in the glow engine field today.
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
       Post #: 89
RE: O.S. 55AX thread - 9/4/2008 4:46:11 PM
mk1spitfire
Status: online
quote:
ORIGINAL: Rambler45
rainedave
here you go mate
hope you can see it
I have just bought the 55ax and it has come with the E-3070 exhaust.
1. Is this a later version exhaust?
2. Is this version LIGHTER in weight than the other.?
3. Is it more rounded than the other and more aerodynamic?
I think the cooling fins are smaller on E-3070.
(in reply to Rambler45)
       Post #: 90
RE: O.S. 55AX thread - 9/9/2008 1:00:43 AM
misterpanda
Status: offline
I believe it's the Great Planes "REVOLVER".
Regards,
Misterpanda
