RE: Charging a Dual Battery Setup - Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: Charging a Dual Battery Setup - Question
Page: <<   < prev  1 [2]
Login
RE: Charging a Dual Battery Setup - Question - 4/8/2008 4:28:46 AM
bodywerks
Status: offline
quote:
ORIGINAL: JNorton
quote:
ORIGINAL: bodywerks
quote:
ORIGINAL: JNorton
Two completely separate chargers will work fine. Do not use a common DC Power supply.
John
Funny - as if it were that simple. If you have been getting by like that with known ground-sensing chargers, charging at the same time, then it is purely by luck. I got this response from Robert Ritchey - the owner of Smart-fly. I think he is a reputable/reliable source:
quote:
You CAN charge one battery at a time even with both batteries connected. You CANNOT charge both batteries at once with a single dual-output charger or two separate chargers if they cannot handle the common ground system. These are rules.
IT is that simple. Two completely separate chargers are not effect by a common ground because there is no return path in the chargers. A dual output charger is NOT the same as two individual chargers. Individual chargers using separate DC supplies will work. SIMPLE. I've designed these things for a living. I do know what I'm talking about.
I meant no disrespect. It didn't click when you talked about using separate power supplies - I guess that might play a part.
Still, I like the idea of a single multi-output charger that can handle common ground systems and not need separate power supplies, so I ordered the Ion A123. It will basically be a field charger powered by a deep-cycle battery and I will simply put the plane on charge after each flight - simple, and there will be no question as to the state of charge of my batteries before each flight. Plus, this will allow me to have an ignition/receiver power system that only weighs 14.5 ounces, which is extremely light for a 42% bird...
_____________________________
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to JNorton)
       Post #: 26
RE: Charging a Dual Battery Setup - Question - 4/8/2008 10:43:14 AM
JNorton
Status: offline
Have fun.
Have desk ... Will Fly....
Saito Member #467
(in reply to bodywerks)
       Post #: 27
RE: Charging a Dual Battery Setup - Question - 4/8/2008 3:01:54 PM
PlaneHeli
Status: offline
I have dual batteries, with dual switches into two different ports on my Rxs.
I am charging using the simple Futaba and Prolux slow (non peak) chargers - (50Mah and 100Mah).
Switching on each switch turns the associated charger's light off.
I assume this is OK and will not damage either battery.
Can anyone confirm this.
Is this common ground problem more associated with digital peak chargers or any charger.
Useless Things...Runway behind you, Sky above you, Air in your Tanks, Engine Oil in the Hanger.
       Post #: 28
RE: Charging a Dual Battery Setup - Question - 4/8/2008 4:08:37 PM
JNorton
Status: offline
It is fine. Both wall warts are transformer powered so their is no return path for the common negative connection on the battery packs.
You only run into trouble using multiple output chargers whose outputs are not isolated internally from each other, or by using a common DC power supply to power mutliple chargers.
John
Saito Member #467
(in reply to PlaneHeli)
       Post #: 29
RE: Charging a Dual Battery Setup - Question - 4/9/2008 7:57:12 AM
PlaneHeli
Status: offline
quote:
ORIGINAL: JNorton
John
John,
Thanks for the reply, Ill continue to use the Futaba slow chargers.
Cheers
       Post #: 30
RE: Charging a Dual Battery Setup - Question - 4/9/2008 11:16:01 AM
JNorton
Status: offline
You're welcome.
Saito Member #467
       Post #: 31
RE: Charging a Dual Battery Setup - Question - 4/9/2008 12:52:23 PM
Sewerdude
Status: offline
So, let me get this right. If I use the standard 50 mah wall chargers and plug each charger into a charge port for my daul battery system. . I dont have to unplug one of the batteries as I would if I used my Hobbico Accu-Cycle Elite???
Every plane has a expiration date!
       Post #: 32
RE: Charging a Dual Battery Setup - Question - 4/9/2008 2:45:48 PM
Flying Geezer
Status: offline
I believe you are correct about dual power supplies not solving the problem with two chargers. You are still tieing the battery negatives to the positive side of the current sensing resistors of the two chargers with the ground bus of the receiver. The problelm is the "low side current sensing". It gets a little complicated.
Flying Geezer
Hughes RC
       Post #: 33
RE: Charging a Dual Battery Setup - Question - 4/9/2008 4:36:53 PM
JNorton
Status: offline
Sewerdude
Wall wart chargers do not have sensing circuitry in them. They are isolated because they use transformers. There is no return path. You can use them safely.
John
Saito Member #467
(in reply to Flying Geezer)
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU1
