craigss11
Joined: 10/5/2006 From: LowoodQueensland, AUSTRALIA Status: offline
quote:
ORIGINAL: karl hibbs I put four more flights on it today. mine has a little up elevator trim. I had to put a rubber band around the hatch to keep it on, later i found that the tank moved back and pushed the hatch off. need to put a piece of foam behind the tank to keep it forward. lots of fun. Actually mine did the same on the first flight,[top hatch flew off]just put a rubber band in through the ply in the hatch and zip tied the other end in the fuse,can't even see the band and looks quite normal. The tank is the issue with the hatch lifting,just put a piece of foam and a zip tie and the problem is solved Mine has been in the air now enough times to have swallowed 5 litres of fuel,my biggest problem is getting both my Pulse planes back from my mates,they love them both ,the 60 mainly but still want to fly the 40 as well LOL LOL Cheers
