silver.kiwi
FL, USA Status: offline
quote:
ORIGINAL: Axel40 Can you fit a decent sized 4 stroke in this plane inverted? All the pics I see of this plane the engine is hanging off the side, not to pretty. I'd be tempted if I could mount inverted with a Saito 1.00 Very nice plane! I mounted mine sideways (the one in the pictures) for a couple of reasons. First I liked the way it looked as opposed to sitting straight up as called for by the manufacturer (beauty is in the eye of the beholder), and secondly because it places the fuel draw from tank to carb. in a more level plain for better engine performance. You could mount it inverted but this would have the fuel draw well below the tank center and might cause flooding or worse, hydraulic lock when starting. As a general rule I have found that four stroke glow engines don't like to be inverted. There is also a greater risk of damage to the engine (push rods and tubes) because of the cylinder being closer to Tera Firma. Having said that, there is always more than one way to skin a cat, so why not give it go and try it inverted. This is a great flying airplane and you will like it I'm sure.
