wedgewing
OH, USA Status: offline
quote:
ORIGINAL: aflipz quote:
ORIGINAL: sb13 The Hacker is 3.7 ounces and my Torque is 5.0 ounces. What motor do you use and whats the weight? Which outrunner do you think I should use? Does'nt have to be one I have, I will order one if needed. Hi, the recomended motors are 105 grams and are rated 900 and 905kv PA makes one called the thrust 30, Extreme flight makes the 2818/900 and apache makes one, i forget what it's called. They are all great motors, pretty much the best match for this airframe and everything that closely resembles it. And Wedgewing; thanks a lot! Welcome aboard. You're addicted to 260's or you aren't right? I have a couple of other videos at vimeo if you would like to see them here's the link, one of them is being updated right now but it should be ready in a couple of minutes. http://www.vimeo.com/user511738/videos Aflipz definitely addicted to the 260s. I have been an E Flite Fan Boy and had only heard of the PA 260 after you had mentioned it. Most of my time on the PA site was spent looking at the Addiction. I am going to see how the 260 3D 480 rebuild goes, but there is no way I am going to drop the money buying new wings, fuse and tail feathers when I could spend that on a PA 260 set up. Maybe I will buy the remains of Fly1252's since he is breaking his cherry on that plane or Woodbenders after his sets on fire in air . can't be any worse outcome than mine. should be enough parts to build one model. The Millennium park PA 260 show looked great. Nice green color on the plane I will let you know if I go PA soon KP
