Duralite & Orbit Pocketlader
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Duralite Support Forum >> Duralite & Orbit Pocketlader
Page: [1]
Login
Duralite & Orbit Pocketlader - 2/3/2008 11:48:06 AM
av8rk
Status: offline
i have a duralite lithium-ion 4,000 ma 7.4 volt 4 cell 2s 2p ECU battery i use on my Jetcat P-60.....i charge it with the duralite charger as per the instructions and everything works as advertised....no problem.....
i also have an orbit pocketlader charger.....can this charger be used to charge the battery described above?
if yes, exactly what settings do i need to set it to.....and, does the charger automatically shut down when a full charge is achieved?...
thanks,
Richard
       Post #: 1
RE: Duralite & Orbit Pocketlader - 2/4/2008 5:28:23 PM
DuraliteTech
Status: offline
Hi Richard,
Yes you can use your Orbit Pocketlader charger on our packs through the yellow charge lead. Simply confirm that the cell count is 2 for 7.4 volts and the charge rate should be no more than 1 amp to protect the Stay Balance Charge Safe circuit from getting damaged. The charger should terminate once the pack is fully charged (8.4 volts) and the current drops down to .05 or below.
_____________________________
Mark
Duralite Tech Support
(in reply to av8rk)
       Post #: 2
RE: Duralite & Orbit Pocketlader - 2/4/2008 5:47:17 PM
av8rk
Status: offline
Thank you Mark for the info...
Richard
(in reply to DuraliteTech)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
