RE: SNFF 0203
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: SNFF 0203
Page: <<   < prev  1 [2]
Login
RE: SNFF 0203 - 2/8/2008 7:10 PM
Generaljumbo
Score: 100
Last Login: 9/24/2008
Status: offline
That looks really good but to be honest i spent more time looking at your work bench
_____________________________
Active HL PzIIIL & Tiger 1
Aut Caesar aut nihil
Hide Signatures
(in reply to pattoncommander)
       Post #: 26
RE: SNFF 0203 - 2/8/2008 10:19 PM
jakeand
Score: 100
Last Login: 3/22/2010
Status: offline
Hi all,
Last weeks I have tested some gearboxes in my Tiger
1. HL metal gear. Ratio 40:1. Whitecap 6500rpm motor
2. Tamtoys metal gear. Ratio 120:1 Blackcap 18000rpm motor
3. Tamtoys metal gear “Stug”. Ratio 67:1 Blackcap 12000rpm motor
All gears were treated the usual way, run in/shimmed/greased and then tested in tank. All measurements (Volt/Amperes/Rpm) were made under the same circumstances. (Same instruments, tracks on and battery pack topped up) Ampere/Watt was measured two ways, with tracks off the ground and tracks skidding on the workbench (steel plate)
Tiger 1
Standard HL 7,2V/1700mah NiCad battery pack
Metal tracks/Wheels
El-Mod electronics.
HL Mg 40:1
Pros.
Metal gears
Hi torque motors
Cons.
Wobbly gearwheels
Wobbly drive shafts
Tamtoys 120:1
Pros.
Metal gears
Possible to use other hi revving motors
Drive shafts running in ball bearings
Ejection marks on gearwheels eliminated
Gear case prepared with a hole for metal suspension mod.
Loads of torque
Cons.
Wobbly gearwheels
Wobbly drive shafts (space between shaft and inner ring of bearing could vary very much, up to 0,2mm)
Noisy (Despite careful running in)
Tamtoys 67:1 “Stug”
Pros.
Machined, not cast metal gears
Quiet
Sturdy gear case
Drive shaft, steady as a rock!
Grub screws Loctited
Low profile
Cons.
Grub screws Loctited (get a pair of new hex keys before you try to loosen these ones!)
You are stuck with the short can motors, if you don’t make an angled gear case mount for one of the motors.
Well, Ive also made a chart for the tested gears with calculated torque (Newton) for the actual setups so we can compare each one (I hope i got those calculations right...if not, feel free to correct me)
Regards Jake
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
"Object on Ebay are closer than they appear" (Heavysled)
http://minipansar.ecommunity.se/
Hide Signatures
(in reply to YHR)
       Post #: 27
RE: SNFF 0203 - 2/9/2008 5:32 PM
Generaljumbo
Score: 100
Status: offline
Wow!
Hide Signatures
(in reply to jakeand)
       Post #: 28
RE: SNFF 0203 - 2/10/2008 3:26 AM
blitzkrieg65
Score: 105
Last Login: 3/21/2010
Status: offline
Excellent work Jakeand, good data cool set up!
The Blitz
RCTankWars.com
Hide Signatures
(in reply to Generaljumbo)
       Post #: 29
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.938RCU1
