Twin Tail SPAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Twin Tail SPAD
Page: [1]
Login
Twin Tail SPAD - 2/4/2008 1:28:26 AM
Villa
Status: online
Last year I totaled my Twin Tail SPAD. It was about 4 years old and had originally been my Pusher Puller. After the two .28 Magnum engines wore out I converted it to a single engine with an OS 46 AX engine, keeping the original twin booms and tail feathers. This version is a better match for a single engine configuration with all new fuselage, tail booms, and tail feathers. Symmetrical 48" wing with 13" cord including 2"ailerons; rear of engine to LE=6-3/8"; TE to end of booms =16-11/16"; booms on 16" centers; CG = 3-1/2 inch but will soon move back a little; AUW = 5LBS; extreme duty 5/32 dia torsion bar main gear with simplified mounting; 6 servos with four inside wing; receiver and battery also inside wing. Currently will not snap roll so I may reduce the vertical stab areas to do some experimenting. Spar has three hard points made from 1/4" aircraft plywood and 1/4-20NC blind nuts to support the front of the 1" X 1/16"square aluminum fuselage and the front of the two 1/16" X 3/4" X 3/4" aluminum boom angles. The ailerons are from the booms out. Between the booms are two 4MM dia carbon rods inserted into two flutes of the rigid portion of the aileron section to provide stiffness.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Twin Tail SPAD - 2/4/2008 4:15:57 AM
AGR413
Status: offline
Looks awesome, good job!
_____________________________
If you are flying, life is good.
(in reply to Villa)
       Post #: 2
RE: Twin Tail SPAD - 2/4/2008 4:47:54 PM
Clean
Status: offline
It'll never work!!!
Pretty cool looking.
Have you thought of making the center section a flap?
From Somewhere near Parkville, Mo.
William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
(in reply to AGR413)
       Post #: 3
RE: Twin Tail SPAD - 2/4/2008 6:11:38 PM
TruBlu02
Status: offline
Very cool plane. I will go ahead and send you a PM so with my home address so you can send it to me for flight testing. I know it is a generous offer but I am just that kind of guy.
< Message edited by TruBlu02 -- 2/4/2008 6:12:08 PM >
(in reply to Clean)
       Post #: 4
RE: Twin Tail SPAD - 2/5/2008 3:45:22 AM
Villa
Status: online
Hi Clean.
Yes that would be a nice spot for a flap. I hate to add anything that is not needed. One of our members had a large Stuka that he landed with flaps and forgot to reset them. Took off with them down and totaled the plane. I just know that would happen to me.
(in reply to TruBlu02)
       Post #: 5
RE: Twin Tail SPAD - 2/5/2008 12:48:10 PM
Clean
Status: offline
Like Clint said, 'Mans gotta know his limitations.'
(in reply to Villa)
       Post #: 6
RE: Twin Tail SPAD - 2/7/2008 3:27:24 PM
Villa
Status: online
Hi Clean. I like that statement. I know my limitations but I keep forgetting them. Two days ago I was flying my Twin Boom in very gusty winds. I wanted to test a change I had made in the CG. After a couple of turns around the field I decided I better land NOW because of the wind. I came down much further away than I normally do and when a down draft hit the plane I did not react fast enough and the plane hit hard. Judging from the dirt on the bottom of the plane (our field is well grass covered) the trike gear bottomed out. Broke the prop and steering rod. No other damage. A balsa plane could have been totaled. My intend is to always touch down in front of me but occasionally I forget. I sure makes life fun though. I'm taking it back up in a few hours.
(in reply to Clean)
       Post #: 7
RE: Twin Tail SPAD - 2/7/2008 5:20:38 PM
Clean
Status: offline
I know what you mean.
I ALWAYS touch down in front of myself, unless I don't.
(in reply to Villa)
       Post #: 8
RE: Twin Tail SPAD - 7/26/2008 6:09:41 PM
vorona.russia
Status: offline
Hello!
This is my twin tail spads
Mercury-1
tested on Evolution 36, flying with saito 82
Harry with JBA 52/// Hi speed!
Mercury-2
(project of DSLR carrier):
Video page here:
YouTube
(in reply to Clean)
       Post #: 9
RE: Twin Tail SPAD - 7/26/2008 6:34:44 PM
DLSmith2
Status: offline
vorona,
Welcome to the forum and the world of fantastic flying plastic!
Your Mercury is very cool! How does it fly for you?
SPAD skies,
DL
(in reply to vorona.russia)
       Post #: 10
RE: Twin Tail SPAD - 7/26/2008 7:37:52 PM
vorona.russia
Status: offline
Thankzzz!
All my planes that IO design fly very well - some video http://http//www.youtube.com/user/wwwvoronaorg
Now I built electric spad. But Merkury-2 fly with two glow engines and one electric motor!
Replaceble parts of Mercury-2
(in reply to DLSmith2)
       Post #: 11
RE: Twin Tail SPAD - 7/26/2008 10:14:52 PM
Villa
Status: online
Hi vorona.russia
Your design for a SPAD V-tail is an excellent idea. Do the two tail wheels allow enough steering to bring the plane back to you? I enjoy steering my twin tail plane around. The elevon servos look small. Are they miniture? If yes, how much torque are they rated for? What material do you use for the engine mount? Does the elevon give you enough function to do a vertical stall turn (I thing it is called an Immeleman).
       Post #: 12
RE: Twin Tail SPAD - 7/27/2008 6:35:13 AM
vorona.russia
Status: offline
Well
This is radio-mix V-tail with both elevator and rudder functions. Ailerons - with flapperon functions/ I use Futaba 351 Gyros on ailerons in Mercury-1 and -2 planes. All 4 wheels are fixed.
(in reply to Villa)
       Post #: 13
RE: Twin Tail SPAD - 7/27/2008 6:52:42 AM
vorona.russia
Status: offline
and if you view videosc of Mercury-2 you can see as rudder work in air? and gyro on ailerons hold the plane strongly
http://www.youtube.com/watch?v=WITz68ItbHM
http://www.youtube.com/watch?v=eFZ5wo5_f4E
       Post #: 14
RE: Twin Tail SPAD - 8/5/2008 10:13:02 PM
vorona.russia
Status: offline
quote:
ORIGINAL: Villa
Elevon servos work fine!
Elevon servos on tail:
Metal Gear HXT 9320 (now not available in hobbycity )
Torque: At 4.8V: 3.8kg/cm , 52 oz/in
Speed: At 4.8V: 0.15sec / 60 deg at no load
Wing aileron servos
HXT 9612 Metal Gear 32g / 5.4kg / .11sec
Low profile servo
Weight: 32g
Dimensions: 42 x 21.5 x 22mm
Torque: 5.4kg-cm
Speed: .11sec/60deg @ no load
Running Current: 610mA
Stall current: 1200mA
Bearing: Yes Dual / M9x7
Gear Type: Alloy / Steel
(in reply to Villa)
