OhD
CA, USA Status: offline
quote:
ORIGINAL: OhD quote:
ORIGINAL: ofremmi DV : No I don't think so, should I ? Jim : I'm not running an idle, the brake is on when the stick is at idle and the trim is at center. If I keep the trim at full down I feel that there is too much stick movement before the engine comes out of brak-mode and starts to pull. I hooked up the JetBox and measured these pulsewidths : Stick at idle, trim at center : 0.996ms Stick at idle, trim at full low : 0.893ms I'm not sure exactly where the arming of the ESC happens with respect to trim position. My point is that I can connect the battery without arming it, and then arm it safely from the transmitter. Ola Sounds like a good setup. I think I will give it a try. Do you get any chattering when you bring the throttle stick up to taxi? I was worried about the gear box getting pounded, Jim Well I decided to give the Spin 99 another try using your approach. I mechanized it a little differently. I used a three position switch on my 14MZ to give me idle, brake and cut off. The settings, with the throttle stick at low, are as follows: Idle, switch up: 1.042 ms, set with ATV/AFR Brake, switch at center: .989ms, set with Idle Down Cut off, switch down: 953ms, set with throttle cut The ESC will not arm until the switch is pulled back to throttle cut, so it must arm between .989 and .953. The system is still safe because in Throttle Cut the throttle stick is disabled. The only bad news is the motor won't start when the switch is pushed up to the idle position like it does on my Hacker/Jeti 90. It is not a serious problem as it will start fairly smoothly with the stick and then it will idle when the stick is pulled back. This allows me to taxi out to the runway and back during practice sessions. It also allows me to use the brake only when I decide I want it. I haven't flown this setup yet so I don't know how good it will work but it works fine on the ground. Jim O
