RE: FUNJET
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> RE: FUNJET
Page: <<   < prev  1 2 3 [4] 5 6 7 8 9   next >   >>
Login
RE: FUNJET - 4/3/2008 4:13:24 PM
chippedprop
Status: online
Yup
The design reduces air flow which is why I started this thread. Take long close look at the remodel pics. The results are a much improved plane.
Vert. it just digs in and goes straight up.
With the motor in the air stream it runs cold which = more power.
The largest prop I run on the e-flite 2700kv is 6x5.5 and the motor is bearly warm.
You should try it. I remodeled one for club member and he can't say enough about the diff. Promise it works.
< Message edited by chippedprop -- 4/3/2008 4:16:35 PM >
_____________________________
PERFORMANCE IS EVERYTHING
(in reply to northchim)
       Post #: 76
RE: FUNJET - 4/3/2008 4:32:31 PM
chippedprop
Status: online
northchim
Always check your flight controls every time. I have only been flying 3 years. I'm self taught on a Stryker which is why I'm good at modifying planes. I either had to mod. (repair) or don't fly.
On a high speed plane make yourself fly at a min. of 100ft off the ground--until you get exp. flying.
I use high and low rates. Low to fly --high to land. On the Mod. FJ on low rates landing it runs out of control--not enough movement on the elevons to control.
High rates I can- on a good day- land with in 10 ft of myself.
I had to learn to think jet. Big sweeping turns. Long approaches with no power.
I still will put the FJ in a vert. climb go till almost out of site. power off-trim to glide and cruise around and grease a landing. Always land into the wind if you can.
I'm sure you know all of this but I didn't and had to crash and rebuild at else 8 times -that's 8 new stryker bodies ( I'm a SLOW learner)
Until I got it right.
Just remember the throttle does not have to go wide open 100% of the time you can fly slower
CP
       Post #: 77
RE: FUNJET - 4/3/2008 5:35:11 PM
ditchit
Status: offline
Yesterday's results on my Mega 16/15/3 and HET 2W23 on 5S and 4.7 x 4.7 APCe were too hot. Far too hot. Last day I will fly before my holiday is tomorrow so needed a setup to give me that last good dose of RC fun before I go.
So today I purchased a Mega 16/15/4 and an array of APCe props. Much coooooler numbers.
Mega 16/15/4 on 4.7 x 4.7 APCe and Flightpower EVO 20 5S3700
Run 1
18.21 Volts
34.6 Amps
0631 Watts
31500 RPM
Run 2
18.03 Volts
34.3 Amps
0619 Watts
31110 RPM
Mega 16/15/4 on 5.5 x 5.5 APCe and Flightpower EVO 20 5S3700
Run 1
19.09 Volts
43.0 Amps
0821 Watts
31350 RPM
Run 2
18.90 Volts
42.5 Amps
0804 Watts
30990 RPM
Going to refit the 16/15/3 and try on a small prop for comparison.
< Message edited by ditchit -- 4/3/2008 5:36:23 PM >
My Club Web site authored by me!
http://fdmac.hampshire.org.uk
(in reply to chippedprop)
       Post #: 78
RE: FUNJET - 4/3/2008 6:20:55 PM
ditchit
Status: offline
Mega 16/15/3 on 4.5 x 4.1 APCe on Flightpower EVO 20 5S3700
Run 1
18.07 Volts
61.5 Amps
1112 Watts
41190 RPM
Run 2
17.92 Volts
60.6 Amps
1088 Watts
40890 RPM
The low warning light on my Hyperion 80A ESC started flashing indicating I was within 0.2V of LVC. And this was on the first very short test. It goes solid red at LVC. So this combo is a no go on my current packs. I'll get a couple of EVO 30s in the near future.
So it looks like the 16/15/4 on 5.5 x 5.5 APCe to start with tomorrow and I'll try the 4.7 x 4.7 as well. Unfortunatley I don't have anything to test thrust with a pusher. Video and write up on flying experience tomorrow afternoon (GMT).
(in reply to ditchit)
       Post #: 79
RE: FUNJET - 4/3/2008 11:11:04 PM
northchim
Status: offline
chippedprop:
That is all good advise. As soon as I get my DX7 programmed the way I want it, things will be much easier. Oh yea, and practice, practice, practice.
       Post #: 80
RE: FUNJET - 4/4/2008 8:02:54 PM
ditchit
Status: offline
Turned up for flying and found that the nuts had come off the end of my servo adjusters. Fortunatley couple of club mates helped me out and I got airborne. Stupidly forgot the video camera, sorry, but it flew very quickly. There was a brisk wind and knowing the distance between 2 tree lines and my time between them at 4 seconds we think downwind speed was 140+ and upwind was 120. Next attempt will be with a 5.5 x 5.5 APCe to see if there's more speed to be had but it was nice and quick as it was. Hitting the beach next week so I'll take some video there. Mega 16/15/4 + 5S3700 + 5 x 5 APCe + 80 OPTO ESC + 740 4.8v Nimh = WINNER!
       Post #: 81
RE: FUNJET - 4/5/2008 2:35:27 PM
tIANci
Status: offline
ditchit ... I am really gonna blame you for this one. Looks like next week I shall be going to the LHS to buy a FJ, ITS YOUR FAULT!!! I got the Mega 16/15/3 for my MJ and I think the MJ is boring now, I cannot do much as the fuse is too narrow. With the FJ I can use my EVO25 4S 2,500 turning an APC 4.7 x 4.25 giving me a pitch speed of 155 mph and only pulling 43A.
Its nice to be important, but its more important to be nice ...
www.rcheadz.com/forum
       Post #: 82
RE: FUNJET - 4/7/2008 1:43:57 AM
chippedprop
Status: online
Well today was a OK day. Stripped a servo in my Mach Racer...but BARELY managed to land YEAH!!!
OK I'll switch to the FJ tossed it up and the wind helped it roll over onto it's back..and you know what's coming.....one side of the brain is yelling PUSH...and the other side is yelling- PULL-- I pulled
***CRASH***
So I'll use the new fuse to transfer all the exp. on this one. I could repair- but this is the 3-4 crash and the 2nd with bad damage.
I'll check all the ele. stuff and if OK will rebuild---again
At least I know what I need to do
CP
(in reply to tIANci)
       Post #: 83
RE: FUNJET - 4/7/2008 9:56:32 AM
tIANci
Status: offline
Chip - sad to hear what happened, that is why for all the small jets I always bungee, much more reliable. Some frens seem to toss with a last minute wrist twist! Hehehehe ...
       Post #: 84
RE: FUNJET - 4/7/2008 6:21:45 PM
Gryphon
Status: offline
chippedprop,
Sorry to hear about your crash.
Not to make light of the crash, but at least the next build will go quick and you can pretty much copy your good design again in a fraction of time that it took you last time....no more head scratching and figuring things out and wondering what if this or what if that.
chippedprop, If you are interested I can lend you my extra motor to check it for a couple of weeks.
It is a MEGA 16/25/2 2650KV and you can feel free to push some amp through it with 3S, 4S or 5S.
It can power you to past 150 MPH in a stock profile Funjet in level flight with no wind. Yours is even more aerodynamic.
I know your motor survived the crash, but I was wondering if you wanted to try a different motor.
If interested send me a PM.
Later buddy,
Gryphon
       Post #: 85
RE: FUNJET - 4/11/2008 4:10:42 PM
chippedprop
Status: online
Couldn't wait reglued the FJ. starting to look worn and sad but still flys
(in reply to Gryphon)
       Post #: 86
RE: FUNJET - 4/11/2008 7:35:56 PM
ditchit
Status: offline
I had a few flights before holiday and when anyone else hand launched for me I got a roll to the left as soon as it left the hand which I caught with a little right aileron BUT on holiday I had 3 failed hand launches which busted up the nose badly. Repairable but I'm not going to launch myself any more. Too high risk. Will fit a hook so I can bungee.
       Post #: 87
RE: FUNJET - 4/13/2008 4:40:32 PM
tIANci
Status: offline
ditchit - on my MJ I will just glue a piece of lite ply to the bottom and then use a screw as the hook, it works fine. Am getting my FJ tomorrow or on Tue ... will get her up ASAP, can't wait to see how fast she goes on 4S.
       Post #: 88
RE: FUNJET - 4/14/2008 5:50:09 AM
northchim
Status: offline
chippedprop: My E-Flight 2700 BL gave out on me this weekend after only 7 or 8 flights. Have you ever had one go out on you before? Since it went out, I'd like to upgrade to a Mega motor. It sounds like the 16/15/3 motor is very popular. I am not looking to go over 100mph just yet though, but having the potential to would be cool. I have several 3s LiPo batteries around so that is most likely the battery I would run most often. Any thoughts?
< Message edited by northchim -- 4/14/2008 6:00:19 AM >
       Post #: 89
RE: FUNJET - 4/14/2008 7:17:51 AM
ditchit
Status: offline
Yeah 16/15/3 is good for 3S and even better on 4S.
