RE: RCGF 100cc Petrol Engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCGF 100cc Petrol Engine
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: RCGF 100cc Petrol Engine - 2/7/2008 1:48:45 AM
Tired Old Man
Status: offline
Yea, I'm going to order one from Driesbabe in the next day or so. I think I need to get his phone number.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to aussiesteve)
       Post #: 26
RE: RCGF 100cc Petrol Engine - 2/7/2008 6:05:21 AM
driesbabe
Status: offline
Ok Guys,
Sorry for not getting back as soon as I have should. I do need to sleep every now and then especially after the party yesterday evening, celebrating the RCGF! Then another Party this morning, as my Daughter turned 3.
OK OK, it went very well. The 100cc started right up and ran a bit rich, range tested the plane and all was good. Then to the skies.
I have flown the YAK before, so that was a non-event. She performed flawlessly, but not a real powerhouse, witch amazed me because of the good prop Nr's I was getting. So I landed and to my amazement the entire plane was full of Oily goo. Then I saw it... I took the wrong fuel can with me. (I have some converted Glow engines that run on 12% oil, and that is what I took)
I begged my friend Richard for some of his fuel (the correct mixture at 32/1) and there we go, we where back at 6800 RPM.
Now, this thin shot of the runway going straight up and not stopping. It is an awesome motor, the Throttle response is right there, it will Idle so smooth and will run up to full power in a blink of an eye. There is one problem though. The prop is too small. It was ripping in straight and level flight at full power, I have never had that.
When I landed after 9 minutes (timer set, as I do not know how much fuel it would use) the tank was still 3/4 full. We put the plane on a fish scale and it reads 50 lbs at full throttle, not bad for a new motor at 6800 foot ASL.
I took her up again and let my friend Mike fly her and immediately sold a Yak and a 100cc engine.
The Yak will hover a half stick and pull out is very strong, with one or two snaps on the upline.
There is not a leak, no overheating no bad anything about this RCGF, Vibrations are non-existent, and the power is awesome (If you remember the right fuel) It is still running a bit rich, but I will fix that on the next time out
I am convinced that these motors will be the next DL's of the Modeling world.
Regards
RCGF Engines Africa
www.pilzers.net
(in reply to Tired Old Man)
       Post #: 27
RE: RCGF 100cc Petrol Engine - 2/7/2008 6:09:37 AM
driesbabe
Status: offline
Sorry, left my camera at home for the Birthday.
Pictures to follow.
Oh and Steve, I don't mind yours being bigger...LOL
As for YAK, make your plane fit the Engine, you will not regret it.
RCGF Engines Africa
www.pilzers.net
(in reply to driesbabe)
       Post #: 28
RE: RCGF 100cc Petrol Engine - 2/7/2008 6:16:03 AM
aussiesteve
Status: offline
Told ya you'd like it
You've discovered the same results as what I found (apart from the wrong fuel issue). It will get even stronger over the next gallon or two (which will take quite a few flights because of how they just sip the fuel).
Keep us (me) posted on your results
What prop are you running? I've been using a wood 27/10 (from the same company that makes Hawke / JXF)
Australian agent for
RCGF engines & Boxes, 33RC airframes, Tzone models, Super Kraft (SK) & others
       Post #: 29
RE: RCGF 100cc Petrol Engine - 2/7/2008 6:22:55 AM
driesbabe
Status: offline
Steve,
The prop is a 28X8 Menz S, I will try a 28X10 once I get one. that's not so easy in Africa.
RCGF Engines Africa
www.pilzers.net
       Post #: 30
RE: RCGF 100cc Petrol Engine - 2/7/2008 8:04:15 AM
yak54
Status: offline
Hi Guys,
Do you know if they will be producing any singles larger than the 65? I really wanted the 100 but it just won't fit
Yak54.
       Post #: 31
RE: RCGF 100cc Petrol Engine - 2/7/2008 8:20:47 AM
aussiesteve
Status: offline
There is a 75 under development - it is in the final testing stages. It will probably be a couple of months away before any of us have stocks of them.
(in reply to yak54)
       Post #: 32
RE: RCGF 100cc Petrol Engine - 2/7/2008 8:53:59 AM
driesbabe
Status: offline
Oh man, I just sold the Yak as is to my freind Mike. He made me an offer I could not refuse
Ah well I will have one in the air flying again soon. He will be putting Tuned pipes on the 100cc, I will let you know what that will bring
RCGF Engines Africa
www.pilzers.net
       Post #: 33
RE: RCGF 100cc Petrol Engine - 2/8/2008 2:30:00 AM
dork_blaster
Status: offline
Since no one seems to know or want to tell how much this will fetch in USD - how much in Aussie dollars?
Blasting dorks for the good of humanity...
       Post #: 34
RE: RCGF 100cc Petrol Engine - 2/8/2008 2:41:32 AM
aussiesteve
Status: offline
You have a PM from me.
(in reply to dork_blaster)
       Post #: 35
RE: RCGF 100cc Petrol Engine - 2/8/2008 5:09:44 AM
Tired Old Man
Status: offline
Ok, so I guess a phone number for driesbabe is a no go. I have one for Ms. Tsang though.
       Post #: 36
RE: RCGF 100cc Petrol Engine - 2/8/2008 5:14:13 AM
aussiesteve
Status: offline
Hi Pat
She won't be available for a few days - It's chinese New Year here so don't be surprised if you don't hear from her 'til next week.
I just sent you a PM with some of the contact info you're seeking
Steve
       Post #: 37
RE: RCGF 100cc Petrol Engine - 2/8/2008 5:15:20 AM
driesbabe
Status: offline
Hi Pat,
I have send you a couple of E-mails, I think you are not getting them.
My Nr's are: 00264 61 225199
or 00264 81 1294050
Cathrine Tsang, is the person to speak to, but I can't get hold of her, she is on Holiday.
RCGF Engines Africa
www.pilzers.net
       Post #: 38
RE: RCGF 100cc Petrol Engine - 2/8/2008 6:37:00 AM
driesbabe
Status: offline
I promised that I would post pictures of my Yak, so here you go.
regards
Andreas
Click to see fullsize image.
Click for fullsize
RCGF Engines Africa
www.pilzers.net
       Post #: 39
RE: RCGF 100cc Petrol Engine - 2/8/2008 8:00:37 AM
Tired Old Man
Status: offline
Driesbabe,
You're right. They were getting caught in my spam folder. I'll try to figure out the time difference and give you a call at a decent hour. I'm guessing about 10 hours to the U.S west coast. Thanks.
       Post #: 40
RE: RCGF 100cc Petrol Engine - 2/8/2008 8:19:26 AM
driesbabe
Status: offline
You Could phone me now, I'm in the Office!
RCGF Engines Africa
www.pilzers.net
       Post #: 41
