driesbabe
Joined: 4/14/2004 From: Windhoek, NAMIBIA Status: offline
Ok Guys, Sorry for not getting back as soon as I have should. I do need to sleep every now and then especially after the party yesterday evening, celebrating the RCGF! Then another Party this morning, as my Daughter turned 3. OK OK, it went very well. The 100cc started right up and ran a bit rich, range tested the plane and all was good. Then to the skies. I have flown the YAK before, so that was a non-event. She performed flawlessly, but not a real powerhouse, witch amazed me because of the good prop Nr's I was getting. So I landed and to my amazement the entire plane was full of Oily goo. Then I saw it... I took the wrong fuel can with me. (I have some converted Glow engines that run on 12% oil, and that is what I took) I begged my friend Richard for some of his fuel (the correct mixture at 32/1) and there we go, we where back at 6800 RPM. Now, this thin shot of the runway going straight up and not stopping. It is an awesome motor, the Throttle response is right there, it will Idle so smooth and will run up to full power in a blink of an eye. There is one problem though. The prop is too small. It was ripping in straight and level flight at full power, I have never had that. When I landed after 9 minutes (timer set, as I do not know how much fuel it would use) the tank was still 3/4 full. We put the plane on a fish scale and it reads 50 lbs at full throttle, not bad for a new motor at 6800 foot ASL. I took her up again and let my friend Mike fly her and immediately sold a Yak and a 100cc engine. The Yak will hover a half stick and pull out is very strong, with one or two snaps on the upline. There is not a leak, no overheating no bad anything about this RCGF, Vibrations are non-existent, and the power is awesome (If you remember the right fuel) It is still running a bit rich, but I will fix that on the next time out I am convinced that these motors will be the next DL's of the Modeling world. Regards
_____________________________
RCGF Engines Africa www.pilzers.net
