driesbabe
Joined: 4/14/2004 From: Windhoek, NAMIBIA Status: offline
Pat, No they do not manufacture the 3mm motor, as far as I know the 26cc, 45cc, 50cc, 65cc and the 100cc are the only products that they make. A family runs the factory, and as Aussiesteve has said, they really want to be the best they can. These are real people that can be trusted and if any problems arise they will deal with it and not just ignore you like so many other Chinese factories I have dealt with. e.g. I had one 26cc come with a standoff bolt that was not properly made, I asked for better QA, and not only received more Bolts added to my next order, but also it seams every engine is properly checked now, as I have not had any more like this. There engines come with painted Heads, I asked to have mine unpainted, and they now come unpainted. I am quite sure that we will in future encounter some problems with the odd motor here or there (as none is perfect), but with the sort of back up and feedback from the factory, I can only see this becoming the next "DL" Oh, if you guys want to find more info on one of their engines, check out a topic called "PEAK 65" that is there 65cc engine. This engine got me to find RCGF, I started it and it ran perfectly from day one and has now got about 30 gallons through it, still getting stronger.
_____________________________
RCGF Engines Africa www.pilzers.net
