Ybenjulkay2x
Joined: 8/7/2004 From: richmond, CA, USA Status: offline
quote:
ORIGINAL: MF35 Hi, Thanks for the reply, can you be a little bit more specific? I am new to this and i need to start with the basics. Where is this switch and where/what is the 'esc'? is that the wire out from the heli with the little red button and when you push it, a red led in a little box lites up? If so, i never tried that. I dont want to be turning too many switches on/off ans i dont want to mess the thing up. One thing that i noticed last night is that when i turn on the control and then connect the battery in the Heli, the led on the gyro will flash while they are initialising and then after a few seconds will switch off completely. From reading the instructions, the LED in the gyro is supposed to stay lit up after initilisation is complete. Would this have anything to do with the DIP switches in the controller? did you got it figure out already?, any way that was the button (red button) you need to press but first turn on the radio, make sure your throttle is all the way down and both switch in your remote (top v1/v2) are up position. about the gyro, the lite suppose to stay on after it initialize.
