35% Extra Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> 35% Extra Build
Page: [1] 2 3 4 5 6 7   next >   >>
Login
35% Extra Build - 2/6/2008 4:36:46 PM
Grotesquebass
Status: offline
Well the day finally arrived today and it came without a scratch i was very pleased to see this after it was with greyhound for nearly a week i can see that this is going to be a very nice plane when done setup is as planned only issure i had was it came with white wheel pants which a quick call to tom revealed they were all packed with whites and he will be sending the yellow ones along with my reciever GREAT service not to mention he is the only guy i know that gives a military discount to us guys proudly serving....thanks tom
DA-100 on Stock Mufflers
AR9100 Spektrum Reciever
5985's on ailerons
5955's on Elevator and rudder
Redundant A123 Packs
A123 Ignition
Kirbys Kustom Graphics
more to come on this list i am sure will post it as i proceed
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Grotesquebass -- 2/7/2008 1:17:17 AM >
_____________________________
"I've got a fever and the only prescription is more cowbell"
       Post #: 1
RE: 35% Extra Build - 2/6/2008 5:04:35 PM
marzo91
Status: offline
I'm on it. I bought PTS' Extra from him. I'll have it on Tuesday. I'm considering a DA 85 for my set-up. Keep us updated.
(in reply to Grotesquebass)
       Post #: 2
RE: 35% Extra Build - 2/6/2008 5:19:57 PM
Grotesquebass
Status: offline
Sweet Please post your progress on here i am going to take a nap i have been up for 36 hours (had the late watch last night) then headed right to annapolis afterwards to get the plane so i am pretty tired but when i get up i plan on going over everything with the iron....i look like a kid on christmas in the pics hehe
< Message edited by Grotesquebass -- 2/6/2008 5:26:42 PM >
(in reply to marzo91)
       Post #: 3
RE: 35% Extra Build - 2/7/2008 1:12:04 AM
Grotesquebass
Status: offline
Well here is my progress not too impressive got the engine compartment pretty much done first i drilled my holes for the da-100 with the template tom provides just be sure the word DA-100 is vertical Not horizontal it really is a no brainer next i reinforced the glue joints with thin ca followed by pinning the firewall with toothpicks and 30 Minute epoxy then to top it off i sprayed the area down with textured paint stuff really works well i used it on my 41% not to mention it looks pretty good.. got my graphics on order today from kirby's kustom more to follow and please as i go i welcome suggestions/comments so dont be shy..
Click for fullsize
< Message edited by Grotesquebass -- 2/7/2008 3:40:01 AM >
       Post #: 4
RE: 35% Extra Build - 2/7/2008 4:03:09 AM
rctom
Status: offline
Be careful with the weight. Every thing you do adds a little weight, after a while it adds up.
My policy is if it's not needed it's not in the plane. Even that paint adds some weight.
This is how I advertise a plane at 26-28 lbs. and it comes out at 30 and people complain without thinking of all the paint, epoxy, batteries, graphics, canisters, power gizmos, and other shiny bits that they put in the plane.
TF
       Post #: 5
RE: 35% Extra Build - 2/7/2008 11:04:16 AM
Grotesquebass
Status: offline
i will keep an eye out on that the way i looked at it was the paint would be lighter then coating the firewall with epoxy for fuelproofing especialy after i sand down the paint so it is just a very thin layer as far as pinning the firewall that is a practice i do on all my planes just for safety reasons i would rather have that little bit of added strength then for it to fail like i said that goes for any airplane.
< Message edited by Grotesquebass -- 2/7/2008 1:47:36 PM >
(in reply to rctom)
       Post #: 6
RE: 35% Extra Build - 2/7/2008 12:33:07 PM
sailing1
Status: offline
On my 35% Sukhoi I just put a piece of clear momokote over the tunnel. Seals the tunnel, lets me see in there and keeps that wieght thing Tom was talking about to a minimum.
       Post #: 7
RE: 35% Extra Build - 2/7/2008 1:47:03 PM
Grotesquebass
Status: offline
ah very good idea sounds like a plan....
(in reply to sailing1)
       Post #: 8
RE: 35% Extra Build - 2/7/2008 2:27:26 PM
rctom
Status: offline
I rarely seal any of the wood, it's not like a glow engine where you get slimy oil all over everything.
But if I do feel; the need to seal the wood a light coat of clear polyurethane sprayed on will do nicely.
Paint pigments are heavy, so colored paint is heavier than clear. Ans using a paint that dries by evaporation (polyurethane) will end up much lighter than something that dries by chemical reaction like epoxy or 2 part paints.
TF
       Post #: 9
RE: 35% Extra Build - 2/7/2008 3:34:34 PM
Grotesquebass
Status: offline
well i figure with a light sanding it will be good to go i am going to cover the cannister tunnel with monokote instead of lite ply to save weight as well
(in reply to rctom)
       Post #: 10
RE: 35% Extra Build - 2/7/2008 4:02:19 PM
rctom
Status: offline
You really don't need to cover it at all.
TF
       Post #: 11
RE: 35% Extra Build - 2/7/2008 4:18:35 PM
Grotesquebass
Status: offline
even if using stock mufflers? would i be alright with opening the holes on the bottom for cooling instead of hacking the cowl up?
(in reply to rctom)
       Post #: 12
RE: 35% Extra Build - 2/7/2008 4:55:17 PM
rctom
Status: offline
quote:
ORIGINAL: Grotesquebass
Yes, in fact that is my preferred way to do it. It keeps the cowl in better shape and provides plenty of cooling and at the same time releases any pressure that might build up in the fuse.
TF
       Post #: 13
RE: 35% Extra Build - 2/7/2008 7:15:35 PM
Grotesquebass
Status: offline
well thats the plan then thanks tom...
(in reply to rctom)
       Post #: 14
