RE: 35% Extra Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: 35% Extra Build
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: 35% Extra Build - 2/26/2008 3:11:57 AM
Sukhoi4Me
Status: offline
I was thinking about just using the Zap glue all around... Anyone have any tips? How big a bead, apply very sparingly...?
(in reply to Sukhoi4Me)
       Post #: 101
RE: 35% Extra Build - 2/26/2008 3:31:42 AM
Grotesquebass
Status: offline
just a thin line then tape it against the hatch side w/ masking tape you should look into that E6000 stuff
_____________________________
"I've got a fever and the only prescription is more cowbell"
       Post #: 102
RE: 35% Extra Build - 2/26/2008 4:50:32 AM
Sukhoi4Me
Status: offline
Here are a few pics of my install. Nothing is set in stone yet. Still need to put smoke tank and smoke battery and plumb it. Need to mount ignition. Not real sure about the rudder set-up.. I am using kevlar cable and have the cables snug but not tight. First time using a JR and it seems awfully twitchy. Still havent set expo or anything.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Grotesquebass)
       Post #: 103
RE: 35% Extra Build - 2/26/2008 11:08:57 AM
Grotesquebass
Status: offline
AHhhhhhh so u do have an airplane heheh
       Post #: 104
RE: 35% Extra Build - 2/26/2008 1:41:18 PM
Sukhoi4Me
Status: offline
Ummmm, yeah! I also have the little Sukhoi... You are going to love yours! I gotta tell you these darn Wild Hares replicate like their namesake!
       Post #: 105
RE: 35% Extra Build - 2/26/2008 3:53:05 PM
Grotesquebass
Status: offline
quote:
ORIGINAL: Sukhoi4Me
you aint gotta tell me i have had about 5 of them lol i ended up not geeting the little suk as dad called me saying i had a 88" Yak from extreme flight on the way
       Post #: 106
RE: 35% Extra Build - 2/26/2008 8:28:05 PM
Panzlflyer
Status: offline
Michaels and other craft stores also sell E6000.
I was thinking of mounting fuel tank underneath (if No cans) and smoke tank on top that way you can remove it easily if you want.
       Post #: 107
RE: 35% Extra Build - 2/26/2008 8:40:50 PM
Grotesquebass
Status: offline
panzl,
did u use the metal pushrod with plastic connector supplied with hardware kit for the throttle ? anyone having rf issues using this setup? maybe tom can help out with this to as i wanna have everything safe for flight i dont see it being a prob with a plastic control arm and the other end insulated with plastic as well just wanna hear if anyone else has this setup
< Message edited by Grotesquebass -- 2/26/2008 8:48:49 PM >
(in reply to Panzlflyer)
       Post #: 108
RE: 35% Extra Build - 2/26/2008 8:45:13 PM
Sukhoi4Me
Status: offline
RF with 2.4 shouldn't pose any problems....
       Post #: 109
RE: 35% Extra Build - 2/26/2008 8:47:50 PM
Grotesquebass
Status: offline
good i am still in the 72mhz mindset as this will be my first plane with 2.4ghz going to do an advanced range check friday and have my wife help me spin the plane around for a minute lol i have pretty much the same remote recievers located same as panzl except i have one on each side of fuse an opposed to one near batteries then the other one is on top of wing tube.......get some more pics sukhoi lets see that beast you get your canopy glued on?
< Message edited by Grotesquebass -- 2/26/2008 8:53:35 PM >
       Post #: 110
RE: 35% Extra Build - 2/26/2008 10:31:54 PM
rctom
Status: offline
If I thought they would be a problem I would not supply them in the hardware kit.
I have used them with dozens of planes and all types of receivers. Just insulate the pushrods from the engine.
       Post #: 111
RE: 35% Extra Build - 2/27/2008 12:06:22 AM
Grotesquebass
Status: offline
i figured as much thank you tom.......
(in reply to rctom)
       Post #: 112
RE: 35% Extra Build - 2/27/2008 1:10:49 AM
Panzlflyer
Status: offline
What Tom said.
2.4 is another ball game...and yes if you dont put expo in it it will be very twitchy, im running 60 to 80% in elevators and rudder, 30 to 40 in ailerons.
The new 9100 has made it even twitchy er....dont know why same plane, just changed, from a 9000 to 9100, maybe the power feed.
       Post #: 113
RE: 35% Extra Build - 2/27/2008 1:55:05 AM
Tired Old Man
Status: offline
What makes them even twitchier is when servos and surfaces are set up extremely close to one to one ratios. At 6 volts or more things get real fast.
Run the travel adjust out to the max and see what it takes to get deflections to the max using the farthest out positioning on the surface side and no more than an inch out on the servo side. You'll likely find you will be farther out on the surface than you would have thought.
30 or 35% expo at low rates and 70 plus at high rates helps a lot too.
If you can''''t fix it with a hammer, you have an electrical problem.
       Post #: 114
RE: 35% Extra Build - 2/27/2008 3:06:14 AM
