Installing balsa sheeting
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Installing balsa sheeting Page: [1]
Login
Installing balsa sheeting - 2/6/2008 9:03:48 PM
ram3500-RCU
Status: offline
I tried something different and it worked so good I thought I would share it here. This time I used Gorilla glue, and held the sheeting in place with 6" stretch wrap. It held the sheet tight and popped right off with a slice from my exacto. It was especially nice as I was dealing with a painted areas and didn't want to use tape. I have pictured the roll of stretch wrap I used. It can be found at Walmart among other places. No pins, no tape, and the Gorilla glue gives you time to get everything where you want it. The stetch wrap holds the wood tight to the sides and gives even pressure over the whole structure, and again, was very easy to remove..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ram3500-RCU -- 2/6/2008 10:38:56 PM >
       Post #: 1
RE: Installing balsa sheeting - 2/6/2008 9:27:12 PM
Edwin
Status: offline
What dept in Walmart.
Edwin
(in reply to ram3500-RCU)
       Post #: 2
RE: Installing balsa sheeting - 2/6/2008 10:14:34 PM
heliothiszea
Status: offline
Thanks for sharing . . . I like the suggestion . . . I'll give it a try. - Seth
_____________________________
Revver #209
(in reply to Edwin)
       Post #: 3
RE: Installing balsa sheeting - 2/6/2008 10:21:26 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: Edwin
Edwin
Look where they keep packaging supplies. I think Lowes and HD have it as well.
(in reply to Edwin)
       Post #: 4
RE: Installing balsa sheeting - 2/6/2008 10:30:12 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: heliothiszea
I applied the Gorilla glue to the framing, and wet both sides of the sheeting, laid it in place and then wrapped it tightly with the stretch wrap. After sitting overnight, it is ready the strip and sand. The Gorilla glue sands like the balsa. For layering, I wet the base layer, applied an even coat of glue to the new piece and wet the back side, then wrapped the whole works. Because you stretch the plastic on, it stays tight till you cut it off. The first wrap takes both hands, but after that, and before you have it too tight, you can slide the sheet if it has moved, than continue around a few more times, and it isn't going anywhere.
(in reply to heliothiszea)
       Post #: 5
RE: Installing balsa sheeting - 3/5/2008 5:39:10 AM
ram3500-RCU
Status: offline
quote:
ORIGINAL: Edwin
Edwin
I was in Walmart tonight and saw the 6" stretch wrap again. It is with the bubble wrap, cardboard boxes, padded envelopes and such. Shipping supplies. A roll long enough to last for dozens of projects is about $8.
(in reply to Edwin)
       Post #: 6
RE: Installing balsa sheeting - 3/5/2008 1:38:43 PM
dhal22
Status: offline
nice!
david
       Post #: 7
RE: Installing balsa sheeting - 3/5/2008 3:49:50 PM
TrickyPig
Status: offline
ram3500-RCU,
GREAT IDEA......you are a smarty pants.....
I will be using this technique very soon.....
Joe
(in reply to dhal22)
       Post #: 8
RE: Installing balsa sheeting - 3/6/2008 12:14:46 AM
ram3500-RCU
Status: offline
Thanks guys. It made this process easier for me this time. Hope it dose the same for you. Please let me know how it works out for you. Nice thing is, the Gorilla glue won't stick to the stretch wrap, so it easy to release and remove.
(in reply to TrickyPig)
       Post #: 9
RE: Installing balsa sheeting - 4/27/2008 3:33:44 AM
Stick 40
Status: offline
I read the CA warning and decided to get away from it as much as I can. This idea and other can make life a lot easier. When I build this winter I will try this.
thanks
I''m a man, I can change, if I have too, I guess. "Red Green"
       Post #: 10
RE: Installing balsa sheeting - 4/27/2008 4:46:41 AM
ram3500-RCU
Status: offline
quote:
ORIGINAL: Stick 40
thanks
When you get ready to try it, just PM me if you need any more info on the process. I'll be happy to help.
(in reply to Stick 40)
       Post #: 11
RE: Installing balsa sheeting - 4/27/2008 4:15:29 PM
WhiteRook
Status: offline
go glue is good at filling voids, which may be good for sheet to ribs or formers, but getting
the sheet down completely is hard to know sometimes, thats why i dont think CA is good for
this , because it sets too fast
       Post #: 12
RE: Installing balsa sheeting - 4/27/2008 5:17:15 PM
ram3500-RCU
Status: offline
quote:
ORIGINAL: WhiteRook
The key to my process is the stretch wrap. This insures good contact of the sheeting to the framing structure. The other thing is the way GO glue cures. It needs moisture. The very thing you want on the balsa sheeting to make it more pliable. Other glues won't stick in such a situation, but that is the very environment Gorilla glue needs. It's all good.
(in reply to WhiteRook)
       Post #: 13
RE: Installing balsa sheeting - 4/27/2008 8:28:12 PM
Stick 40
Status: offline
will do, I may start this summer or fall if time allows.
thanks
       Post #: 14
RE: Installing balsa sheeting - 5/10/2008 2:24:45 AM
Appfan
Status: offline
Great use for this stuff. Thank you.
I used this over the past week to put the final sheeting on the center section of a wing kit I'm working on. I only had to add 1-2 pins on each piece of sheeting. Great technique here.
       Post #: 15
RE: Installing balsa sheeting - 5/10/2008 2:52:35 AM
Dorsal
Status: online
Hmmm - Does anyone know if that stretch wrap sticks to epoxy?
If not, it would be a great way to get epoxy/fiberglass/carbon/kevlar onto a fuselage or boat hull.
(in reply to Appfan)
