AFSalmon
Joined: 5/24/2002 From: Beavercreek, OH, Status: offline
Got the OS 55AX and tank installed last night. All the radio is installed and I'm going to try out the Hitec HS77 servos all the way around. Good specs on the servos for anologs and they are relatively inexpensive. A slightly bigger case than standards but the servo openings were easily trimmed to fit the HS77s. Weight so far is 4 lbs 4 oz RTF dry. I'm using a Hitec Electron 6 rx and 1100 5 cell NiMH battery. Thursday up here in OH looks dry and clear although it will only be 30 degrees. Can't have perfect weather but I'll be shooting for the maiden tomorrow after work!
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer Ohio Model Planes, Team OMP Captain
