SIG Somethin Extra wing attachment
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> SIG Somethin Extra wing attachment Page: [1]
Login
SIG Somethin Extra wing attachment - 2/7/2008 7:23:07 PM
flyingfever
Status: offline
The fever is back!
The UPS man dropped a package on my front porch a couple hours ago, and I am now deep into the first read of the instruction book for my new SSE.
I've built a few kits over the years; PT-40, Easy Sport, 4 Star 40. But today I am determined that this will be the best build ever!
So I'm going to need some advice along the way, right?
First detail that jumps out at me is these J-Hooks and rubber band to hold the wings onto the fuselage. Is that really a good idea?! I can't imagine I would ever feel secure while flying with just a rubber band between my plane's wings and and a serious re-kit incident.
There must be a more secure method.
Any ideas are welcome.
Fever
       Post #: 1
RE: SIG Somethin Extra wing attachment - 2/7/2008 7:34:24 PM
MasterAlex
Status: offline
I use a Zip Tie on mine instead of a Rubber Band - never had an issue!
_____________________________
The 1st step is admitting you have a problem ... okay, I admit it, RC is my obsession!
(in reply to flyingfever)
       Post #: 2
RE: SIG Somethin Extra wing attachment - 2/7/2008 8:49:59 PM
Acs_guitars
Status: offline
Here's an idea for you... I have never tried this, but I have seen it work well.
Click to see fullsize image.
Click for fullsize
Originator of the Web Crawlers Association WCA# 0001
AMA # 880471
(in reply to MasterAlex)
       Post #: 3
RE: SIG Somethin Extra wing attachment - 2/7/2008 9:19:37 PM
r2champion
Status: offline
Considering that the forces involved in holding the wing halves together are very small, the rubber band will work with no problems. The only time there will be any considerable forces pulling the wing outward should be during a fast roll, still no concerns with the stock setup. As a matter of fact, I have heard stories (both good and bad) that the plane was flown without anything holding them together because the pilots forgot to put it on. However, I use a rubber band and a zip-tie just for redundency. Use what you feel confident with, but I see no reason for any big modifications. Like they say, If it aint broke, don't fix it!
My intials are "RC", I guess it was meant to be!
(in reply to Acs_guitars)
       Post #: 4
RE: SIG Somethin Extra wing attachment - 2/7/2008 9:52:18 PM
Acs_guitars
Status: offline
I agree that there is really no problem with rubber bands being used and I am sure it would hold up fine. The zip tie is the easiest way to go for the added security. If you feel a change is neccesary, go for it and mod to your hearts content... something can always be improved.
AMA # 880471
(in reply to r2champion)
       Post #: 5
RE: SIG Somethin Extra wing attachment - 2/7/2008 10:01:26 PM
daveopam
Status: offline
Whenever there is a load on the wings the wing tube is pressed against the inside tube. The rubber band does nothing. I have floen several of these vary hard with no problems.
David
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
       Post #: 6
RE: SIG Somethin Extra wing attachment - 2/7/2008 10:07:39 PM
*JCB*
Status: offline
I guess i'm extra paranoid as i use a rubber band AND a zip tie. I've heard about people putting a small slice in the rubber band on the hooks, while installing them, compromising their strength
With a new found love for my SSE (for some reason i used to hate flying it ), i flip and flop this plane all over the sky w/o any problems. This plane is such a performer that i feel it is necessary for something stronger and more reliable than a rubber band. I'm sure a zip tie alone would be perfect, especially if you have fat fingers, as getting three loops on a rubber band inside the tight fuselage can be a pain!!
EDIT: Spelling
< Message edited by *JCB* -- 2/8/2008 1:31:27 AM >
Shake Things Up!
       Post #: 7
RE: SIG Somethin Extra wing attachment - 2/7/2008 10:52:54 PM
frenchie79
Status: offline
I'm just finishing the construction of the SSE. Really nice plane to put together. I had the same concern, what I did was add blind nuts to the end rib at the location for the wing bolt. Easy to do and works great. Just drill out and add a 4-40 blind nut to the inside of the rib. I'll use rubber bands to hold it tight, but will zip tie it also for added measure-a small bag of a hundred cost nothing.
You will love the build.
Frenchie #193
       Post #: 8
RE: SIG Somethin Extra wing attachment - 2/8/2008 4:17:27 AM
ChuckW
Status: online
The rubber bands will work just fine. You could also get a small spring at the hardware store to accomplish the same thing but with less worry of it breaking.
       Post #: 9
RE: SIG Somethin Extra wing attachment - 2/8/2008 11:58:11 AM
yel914
Status: offline
I used the blind nuts on the inside of the root ribs with the provided J hooks. I located a spring with loops on each end at the hardware store that was perfect for the job and very easy to put on at the field. Worked great.
WACO Brotherhood #24
(in reply to ChuckW)
       Post #: 10
RE: SIG Somethin Extra wing attachment - 2/8/2008 2:50:10 PM
flyingfever
Status: offline
Thanks all,
I like the zip tie idea. Simple and secure. And cheap.
Still reading thru the build instructions. Hope to start building this weekend.
Any recommendations for an engine? I really like four strokes.
Would a Saito 62A be a good match for this airplane?
Fever
(in reply to yel914)
       Post #: 11
RE: SIG Somethin Extra wing attachment - 2/8/2008 3:01:22 PM
frenchie79
Status: offline
I have not used that-but heard it was an excellant match. 46 two strokes work great so that should be fine.
Frenchie #193
       Post #: 12
RE: SIG Somethin Extra wing attachment - 2/8/2008 3:54:54 PM
daveopam
Status: offline
Mine has a Saito 72. If you want to sport fly a 62 will be plenty. The 72 will hover it at 65% or 70% throttle with a 13x4W.
david
(in reply to frenchie79)
       Post #: 13
RE: SIG Somethin Extra wing attachment - 2/8/2008 5:19:05 PM
djr1007
Status: online
Just my 2 cents, but why not put a blind nut in the root rib and use a 1/4 20 nylon thumb screw? my showtime is that way, my 1/4 Yak is that way, never had the slightest problem, much easier than hooking the rubber bands.
(in reply to daveopam)
       Post #: 14
RE: SIG Somethin Extra wing attachment - 2/8/2008 9:23:37 PM
frenchie79
Status: offline
That is a good idea. I still like the idea of a little give in the event of a less than steller landing, but then again the tube and everything would get wacked. How do you tighten the nylon nut, with a socket/rachet?
Frenchie #193
(in reply to djr1007)
       Post #: 15
RE: SIG Somethin Extra wing attachment - 2/11/2008 12:05:48 AM
carrellh
Status: offline
Thumb screws have a knurled head and you screw them in with your fingers.
http://www.smallparts.com/products/descriptions/tsn.cfm
