Cyberwolf
ID, USA Status: offline
I fire up the Mac today ,Here is what my setup was tower plug, 3 head shims 15% castor syn fuel, 11x7 APC Open header I got a reading of 12,650 fairly constant. I varied the RPM's for 2 full tanks which is only 4 OZ.each I added the pipe and was getting a whopping 11,400 so I started cutting the header down a 1/4 inch at a time to try to bring it in. after I had cut off 1 1/2 inches the RPM's finally come up to 12,000. I have set up several pipes in the past but I have never seen one that wouldn't improve adding the pipe from a open header right off am I forgetting something here? or do I just need to shorten it more? And just for Dave I tried a 11x7 Zinger prop cause I know he will tell me to *S* the results was less than desirable about 900 less than the APC. But spool up was nice. As a rule I mark the head of the piston before removing it ,but I didn't on this one ! I was expecting a chamfer on one side of the large end of the rod and didn't really pay any attention to which way the piston faced untill I seen it has one skirt with a cut out in the bottom of it. Looking it over I decided that this went to the front of the engine to clear the front ports, Was I correct in this asumption? I forgot to add this the engine is leaking alot of fuel from the front bearing ,which is not sealed but as a rule I have found what causes this is to much clearance between the housing and shaft also it would spit fuel out of the carb at certain RPM's, like it was building up crankcase pressure. I know it was going thru fuel like gangbusters ,but I had it leaned out both on the bottom and top ends. Kmot I apologize for saying your RPM's was low heck id settle for those figures about now *LOL*
< Message edited by Cyberwolf -- 4/3/2008 6:59:13 PM >
_____________________________
I've learned that you cannot compare yourself to others -they are more screwed up than you think.
