RE: Hi Perf Russian 10cc at a bargain price!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Hi Perf Russian 10cc at a bargain price!
Page: <<   < prev  8 9 10 11 12 13 14 15 [16] 17   next >   >>
Login
RE: Hi Perf Russian 10cc at a bargain pr... - 4/15/2008 10:42:11 PM
Flyboy Dave
Status: offline
....an 11-7 1/2 Master Airscrew or Zinger should work.
FBD.
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to Ed Cregger)
       Post #: 376
RE: Hi Perf Russian 10cc at a bargain pr... - 4/15/2008 11:29:27 PM
XJet
Status: offline
quote:
ORIGINAL: Ed Cregger
An inexpensive "chunk burner" wood stove would run you out of your shed, insulation or not, with its heat.
Maybe, but with 44 gals of methanol and other volatile solvents and the issue of moisture condensation on a cold tin roof overnight, combustion-type heaters aren''t a good idea :-(
When I'm not here, I'm at RCModelReviews
       Post #: 377
RE: Hi Perf Russian 10cc at a bargain pr... - 4/15/2008 11:41:45 PM
mmattockx
Status: offline
quote:
ORIGINAL: XJet
Maybe, but with 44 gals of methanol and other volatile solvents and the issue of moisture condensation on a cold tin roof overnight, combustion-type heaters aren''''t a good idea :-(
Chicken!!
Mark
Waco Brotherhood #4
(in reply to XJet)
       Post #: 378
RE: Hi Perf Russian 10cc at a bargain pr... - 4/16/2008 12:08:22 AM
XJet
Status: offline
quote:
ORIGINAL: mmattockx
quote:
ORIGINAL: XJet
Maybe, but with 44 gals of methanol and other volatile solvents and the issue of moisture condensation on a cold tin roof overnight, combustion-type heaters aren''''''''t a good idea :-(
Chicken!!
I don''t mind being a chicken but I draw the line at being a roast-chicken :-)
(in reply to mmattockx)
       Post #: 379
RE: Hi Perf Russian 10cc at a bargain pr... - 4/16/2008 11:00:33 PM
slopflyer
Status: offline
Here are some photos of origianal russian MDS 10 KRU( МДС 10 КРУ ).
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by slopflyer -- 4/16/2008 11:02:15 PM >
(in reply to XJet)
       Post #: 380
RE: Hi Perf Russian 10cc at a bargain p... - 4/16/2008 11:07:07 PM
Kmot
Status: offline
Oh, how lovely!
Thanks for posting these photos! I wish our versions had come with the tuned pipe. Can you please give us the dimensions of the pipe? Overall length, diameter of cone, distance of cone ring from inlet, and distance of cone ring to outlet.
Ahhh......screw it!
(in reply to slopflyer)
       Post #: 381
RE: Hi Perf Russian 10cc at a bargain p... - 4/18/2008 1:45:12 PM
slopflyer
Status: offline
What happened? Some posts disappeared include mine.
I try upload pipe's photo with dimensions one more time.
This pipe made by very light but soft Al, and Thickness is about 1mm through out the whole.
And biggist diameter in the middle of pipe is about 40mm.
I didn't set up mines yet, so I don't know the other parameters.
Click for fullsize
(in reply to Kmot)
       Post #: 382
RE: Hi Perf Russian 10cc at a bargain p... - 4/18/2008 4:05:22 PM
Kmot
Status: offline
@slopflyer: Thank you very much!!
Yes, there have been many problems on RCU for a few days now with photo uploads and other issues.
Ahhh......screw it!
       Post #: 383
RE: Hi Perf Russian 10cc at a bargain p... - 4/26/2008 9:49:32 PM
mmattockx
Status: offline
Is anybody working on headers for this engine? XJet, maybe? I am still interested in a couple if they are in progress.
Mark
Waco Brotherhood #4
(in reply to Kmot)
       Post #: 384
RE: Hi Perf Russian 10cc at a bargain p... - 4/26/2008 11:05:48 PM
XJet
Status: offline
I must admit that since the crankshaft on mine fell apart I've not given much attention to the header issue. I'm just about to head down to the workshop and start machining a new front housing, crankshaft and rear disk-valve set-up for my MDS so I'll probably have a better idea what sort of timeframe I'm working with soon.
       Post #: 385
RE: Hi Perf Russian 10cc at a bargain p... - 4/27/2008 12:09:31 AM
Kmot
Status: offline
Take pictures of the process. I would love to see how you make the parts.
Ahhh......screw it!
(in reply to XJet)
       Post #: 386
RE: Hi Perf Russian 10cc at a bargain p... - 4/27/2008 4:38:29 AM
BlackB12
Status: offline
I swore I posted my first filght test but it appears to have been deleted by someone. Anyway here it is again. http://youtube.com/watch?v=7JYD1x9NTYk
I've since changed the prop to a wood 11x6, down from the apc 11x7 seen in the video. Much much better. Didn't tach it but it screams and the transition is very fast with the lighter prop load. Pipe length I didn't change yet but with the smaller prop it's definitely better than the first flight.
The only negative is now the carb barrel is trashed. The throttle stop screw must've back out enough to cause the barrel to move. Now the groove in the barrel has to dimples in it and the carb will get stuck when it rotates to these areas. Totally killed a throttle servo on the last flight. Luckily the throttle locked just above idle and I landed safely. So, it's grounded until I either repair the barrel or find another carb that will work.
Mike
(in reply to Kmot)
       Post #: 387
RE: Hi Perf Russian 10cc at a bargain p... - 4/27/2008 4:59:06 AM
Kmot
Status: offline
Mike, you can use a needle file to remove those dimples. Maybe that will solve the problem.
The engine sounds awesome in your video!
Ahhh......screw it!
(in reply to BlackB12)
       Post #: 388
RE: Hi Perf Russian 10cc at a bargain p... - 4/27/2008 5:27:48 AM
XJet
Status: offline
The barrel screw on mine broke off where it was turned down from the threaded portion so I made a new one. Works fine now (wish I could say the same for the crankshaft though -)
(in reply to Kmot)
       Post #: 389
RE: Hi Perf Russian 10cc at a bargain p... - 4/27/2008 10:16:54 PM
