DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: online
quote:
ORIGINAL: daven ...Heat got the sleeve out, but I still haven't been able to get the rear bearing off the crank. I did get both bearings to freed up from the gunk in them with Brake cleaner, acetone, and Marvel Mystery Oil. Will try to reheat tomorrow to get the rear bear off. Dave N, Tom, Having the crankshaft come out with the rear bearing on it is, in nearly all cases, a user error. Heat must be applied to the crankcase, only after the crankshaft is already out. ... After removing the prop-driver from the front of the crankshaft (and of-course the piston, sleeve, Etc.) and with the crankcase still cold, pushing back on the front of the crankshaft will get it out (unless the fit is wrong). The 'grip' of the rear bearing's inner race on the crankshaft is much weaker than the grip of the cold crankcase on the rear bearing's outer race, so the crankshaft should slide out and leave the bearing inside. Only then must heat be applied to the crankcase, to cause the bearing to release and fall out, through heat expansion coefficient differential. The application of heat early on, heating the similar steels of the bearing and the crankshaft... There will not be any relative expansion of the bearing's inner race, compared to the crankshaft... The bearing will not release from the crankshaft due to the heat! Only the crankcase expands more and the crankshaft + bearing assembly will go out as one piece... The easiest way to remove the rear bearing from the crankshaft is... ...to reassemble it in the crankcase. Reheat the crankcase; drop the crankshaft + bearing assembly all the way home; cool the whole assembly in the freezer (this will cause the aluminium crankcase to grip the rear bearing's outer race even more strongly. It will not change the strength of the inner race's grip on the crankshaft, since both will cool and contract the same amount. Now, push the crankshaft back and out. The rear bearing will remain in the crankcase.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
